Roms wont flash TWRP
50 replies to this topic
#1 Deacon
Deacon
  • 68 posts
  • LocationUSA
Posted 17 June 2013 - 11:16 AM
Trying to flash Eclipse v5 from eclipserom.com, i wipe everything, that works, then reboot recovery mount everything  flash and it says failed, but when i unmount everything and flash it claims to have finished but it actuality didn't, what gives? I seem to be the only one with this problem..
#2 Deacon
Deacon
  • 68 posts
  • LocationUSA
Posted 17 June 2013 - 01:57 PM
anyone ? i cant flash roms...
#3 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 17 June 2013 - 02:18 PM
Have you tried CWM??
Also why are you mounting "everything"??
It should be wipe data, cache, dalvik, system, then mount system and flash rom.
  • shane1 likes this
#4 neckchop
neckchop
    pluh!
  • 477 posts
  • Locationatlantic City
Posted 17 June 2013 - 03:42 PM
Have you tried other ROMs or redownloaded eclipse? (Definitely worth flashing!).
This might be a ridiculous question,.but you'd be surprised....
Are you bootloader unlocked using twrp? If so which version?
You aren't using safe strap are you? (Easy mistake, visually very similar)
#5 Deacon
Deacon
  • 68 posts
  • LocationUSA
Posted 17 June 2013 - 05:01 PM
Yeh unlocked running 2.5 twrp from 2.3 thought it would solve the problem and now I've been waiting for eclipse I install it then the files don't show up and no boot
#6 Memnoch73
  • 5,016 posts
Posted 17 June 2013 - 05:08 PM
Are you flashing g-apps at the same time? I have seen some AOSP roms that don't boot without the g-apps flash at the same time as the rom
#7 Deacon
Deacon
  • 68 posts
  • LocationUSA
Posted 17 June 2013 - 05:13 PM
Yeah I am.
#8 Deacon
Deacon
  • 68 posts
  • LocationUSA
Posted 17 June 2013 - 05:16 PM
I've rooted many droids I was thinking of flashing in safe strap and loading the backup. As the restore function works. Thank god.
  • neckchop likes this
#9 shane1
shane1
    Droid Elite
  • 1,596 posts
  • Twitter:1shane15
  • Locationny
Posted 17 June 2013 - 05:19 PM
do you have safestrap installed now?
sig made by
Rinkle McBally
#10 Deacon
Deacon
  • 68 posts
  • LocationUSA
Posted 17 June 2013 - 05:21 PM
No. Never even tried it.
#11 shane1
shane1
    Droid Elite
  • 1,596 posts
  • Twitter:1shane15
  • Locationny
Posted 17 June 2013 - 05:26 PM
did you try another rom?
sig made by
Rinkle McBally
#12 CamoCustom
CamoCustom
  • 193 posts
  • Current Device(s):Razr M
Posted 17 June 2013 - 05:28 PM
The process I have been using for flashing roms on my unlocked device are: (twrp 2.5) wipe cache/dalvik, data, wipe system. Reboot recovery, mount system, flash rom and gapps then reboot. I used this method for eclipse 5.0, pacman, cm10 + 10.1,and slimbean. Did it this morning for 6/16 pacman update coming from eclipse.<br /><br />**Don't forget to backup your last working roms/stock, unless you like starting all over.... <br /><br />Sent from my DROID Razr M<br />
#13 shane1
shane1
    Droid Elite
  • 1,596 posts
  • Twitter:1shane15
  • Locationny
Posted 17 June 2013 - 05:30 PM
try without mounting, it has the kernel in it so you shouldnt have to.
sig made by
Rinkle McBally
#14 neckchop
neckchop
    pluh!
  • 477 posts
Posted 17 June 2013 - 05:32 PM
try without mounting, it has the kernel it it so you shouldnt have to.
Yes, I loaded eclipse 5.0 without mounting anything, flashed the first time with no issues, booted up pretty quickly too
  • shane1 likes this
#15 neckchop
neckchop
    pluh!
  • 477 posts
Posted 17 June 2013 - 05:33 PM
Have you considered that you have a bad download? I had to try three times to get a download, but that was in a weak signal area... Just a thought
#16 shane1
shane1
    Droid Elite
  • 1,596 posts
  • Twitter:1shane15
  • Locationny
Posted 17 June 2013 - 05:35 PM
you only need to mount for roms that do not have a kernel. If your unsure look in the zip for a file named Boot.img
sig made by
Rinkle McBally
#17 Deacon
Deacon
  • 68 posts
  • LocationUSA
Posted 17 June 2013 - 05:43 PM
I'm redownloading eclipse now will let you know how it goes
  • neckchop and shane1 like this
#18 CamoCustom
CamoCustom
  • 193 posts
Posted 17 June 2013 - 06:00 PM
Don't most roms now have their own kernel? As in cm10.1,pac,etc?<br /><br />Sent from my DROID Razr M<br /><br />
#19 shane1
shane1
    Droid Elite
  • 1,596 posts
  • Twitter:1shane15
  • Locationny
Posted 17 June 2013 - 06:01 PM
all the 4.2.2 roms do , as far as i know
sig made by
Rinkle McBally
#20 Memnoch73
  • 5,016 posts
Posted 17 June 2013 - 06:02 PM
Kind of... It's still a changeover because before the Bootloader unlock they did not need them due to the way safestrap worked. We are now still in the transition period back to normal rom flashing style.
