6.14.85? Is It For Cdma?
Posted 07 May 2012 - 09:30 AM
Posted 07 May 2012 - 09:36 AM
Posted 07 May 2012 - 10:07 AM
We can go from 84 to 85 or 85 to 84. Fastboot force the 6.12.181 files, moto recovery to the update of your choice with installing the zipAs far as I know there is no way to go from 84 to 85 since we cannot fastboot back to 173 or 181 at the moment
Posted 07 May 2012 - 10:12 AM
I stand corrected. So if we fastboot back to 181 does that put us back on the upgrade path??
Posted 07 May 2012 - 10:34 AM
I did not know we could flash between .84 and .85... KI have the .181 FB files what needs to be done to get to .85 from .84?
Flashing fastboot files will fail as I understood it so how do you 'Force' them so I can install then .85 ZIP?
Posted 07 May 2012 - 10:40 AM
If this is true, why dont we get everyone stuck on the same leak so we do not run into issues once a fix is found. Also I read before that you can NOT go from 84 to 85. In fact wasnt it posted in bold red?? Not saying your a liar but if this is the case I would love to get on to. 85.
Sent from my Axiom MAXX!
Posted 07 May 2012 - 10:42 AM
Sent from my Axiom MAXX!!
Posted 07 May 2012 - 10:49 AM
Posted 07 May 2012 - 11:14 AM
Because I've tried this method and the .85 update fails at boot check.
.84 to .85 even fails on hw diag bp boot?
X
Posted 07 May 2012 - 11:46 AM
So .84 to. 85 does not work correct? I have 84 set up the way I like but I head 85 has a different kernel?
Posted 07 May 2012 - 12:07 PM
Can someone on .85 post their kernel info for a comparison?
Posted 07 May 2012 - 12:24 PM
Posted 07 May 2012 - 12:27 PM
Posted 07 May 2012 - 12:29 PM
If one other condition is met, yes. That condition being that the OTA must be the same as, compatible with, or higher version than the one included in .84/.85.
Posted 07 May 2012 - 12:35 PM
Posted 07 May 2012 - 12:39 PM
So does this work or not?
Ummm... you may want to be more specific. Are you talking about CDMA 85, fastbooting back to 81, going from 84 to 85, kernel versions or OTA updates??? Guess we slid a bit off topic. Lol...
Posted 07 May 2012 - 12:47 PM
Posted 07 May 2012 - 02:42 PM
Posted 07 May 2012 - 02:52 PM
Posted 07 May 2012 - 03:33 PM
You can't start a frenzy and leave us! Geez you are like a Lost season finaleWe can go from 84 to 85 or 85 to 84. Fastboot force the 6.12.181 files, moto recovery to the update of your choice with installing the zip
