Battery Prob, Og Razr Converted To Maxx.
Posted 13 May 2012 - 11:01 AM
After i see 15% i power down and plug in. Itsshowing 20% and has for last 40 min.
Ihavehad crazy battery readings on my phones before, but could always fully charge run down, power off n fully charge again to fix the readings. With this thing i cant even get it to cycle. I was just wondering if anyone who has converted to maxx hasnoticed anything like this? Or is this battery just foobared?
I got thatlong or more on og razr. Would a fact reset help?
Thanks, and hope this all makes sence lol
Posted 13 May 2012 - 11:23 AM
I got a Motor Razr. I will.....cut you.
Posted 13 May 2012 - 11:34 AM
Posted 13 May 2012 - 11:47 AM
Posted 13 May 2012 - 12:36 PM
try to power on and let it die
Recharge for 4 hours leaving it off
let it get to 100% then run the android app battery calibration
Posted 13 May 2012 - 12:49 PM
Thanks for the help guys. This is a new prob for me:huh:
Posted 13 May 2012 - 12:51 PM
Posted 13 May 2012 - 02:04 PM
Hope this works.
I know others have modified to a maxx. Has anybody else had this problem?
Posted 13 May 2012 - 04:39 PM
Posted 13 May 2012 - 05:24 PM
Lol motherboardWtf is a mobo? Even auto correct doesn't like that one.
Posted 14 May 2012 - 03:01 AM
I really believe the og had better life. Maybee its just a bad battery.
Posted 14 May 2012 - 03:04 AM
Posted 14 May 2012 - 04:23 AM
Posted 14 May 2012 - 07:03 AM
LET THE BATTERY DIE
I thought we've already established that you don't need to calibrate battery
Posted 14 May 2012 - 09:17 AM
As far as i know BATTERIES dont calibrate, but the hardware/ software that guages them does.I thought we've already established that you don't need to calibrate battery
Posted 14 May 2012 - 09:59 AM
Posted 14 May 2012 - 10:03 AM
Posted 14 May 2012 - 10:08 AM
I have the same problem and I'm also on the leak. My phone was turned off and charging. Said it was at 40% and I decided to turn it on. Once it booted up I was at 78%. Second time this has happened too.
I am actually stock 181. But its agvating as all get out. I got better battery as an og razr.
One question is if powered off and it shoes 100% will it still charge or does it turn off charging? I ask bcause it will show 100% while off and like 60 r when i power up. Can i just leave it off, or will it stop charging if shows 100
Posted 14 May 2012 - 01:07 PM
