ROM Recommendations for my Maxx HD
Posted 28 June 2013 - 01:48 PM
HTC One M8 // 3.28.605.4 // CleanROM 3.0 w/HarmonKardon audio // Android 4.4.4
- "White Noise" out November 4th! (Recommended)
Posted 28 June 2013 - 02:01 PM
my hd was running SlimBean for almost 2 months start, loved it
How's the data connection?
Sent from my DROID RAZR MAXX HD using Tapatalk 4 Beta
Posted 28 June 2013 - 02:14 PM
seemed fine
I may give it a try.. I love 4.2 but that data connection isn't as good as stock on CM10.1, that's why I ask. Thanks pal. Any other ROMs you've tried that are pretty good?
Posted 28 June 2013 - 02:36 PM
I was running Eclipse before I switched to the S4
- zooyork0721 likes this
Posted 28 June 2013 - 02:37 PM
The 4.2 or 4.1 version?
- maryvate1 likes this
Posted 28 June 2013 - 03:03 PM
before video was fixed i ran axi0m for almost 2 months . Now i mostly run cm until all the bugs get fixed
sig made by
Rinkle McBally
Posted 28 June 2013 - 04:26 PM
- droidian1441, razzrmaxx and zooyork0721 like this
Posted 28 June 2013 - 05:09 PM
4.1 4.2 ROMs are too buggy for me. I prefer stock based.
- droidian1441 likes this
Posted 29 June 2013 - 12:29 AM
Sent from my DROID RAZR HD using Tapatalk 4 Beta
Posted 29 June 2013 - 07:07 AM
Posted 29 June 2013 - 08:31 AM
I tred Axiom, CM, Eclipse but Rage RoM felt better battery wise and performance, since Rage is based on the 4.1.2 stock kernel everything worked... but then i tried RageWizz and i havent found a bug since i installed it almost 3 weeks ago now, and the data tweaks makes the internet fly check the picture below
Does RageWizz still have density and app installation issues? (I know the density was the cause of the app issues in the first version, haven't tried any other versions, if any.)
Posted 29 June 2013 - 10:11 AM
Thats easily solved with pimp my rom density changer: after you change that, you can see all apps on the marketDoes RageWizz still have density and app installation issues? (I know the density was the cause of the app issues in the first version, haven't tried any other versions, if any.)
Posted 29 June 2013 - 01:27 PM
Posted 29 June 2013 - 03:23 PM
Bloated? I dont know how many apps or what apps you consider to be bloat, i froze or removed the ones i didnt need with titanium backup its as Simple as that too or you can leave everything on the devs hands and wait till they fix every little tiny issue on the 4.2 versions out there which they might not because they're probabbly leave that developmen to move to 4.3 lol, just like they're leaving 4.1.2Isn't ragewizz more bloated? I know it's from the same dev. Just curious of why anyone would want to run touch wiz on a non Samsung device? I ran AOKP on my sg3 when I briefly had it.
Posted 29 June 2013 - 03:26 PM
Posted 29 June 2013 - 10:04 PM
Fine since you inssist, im going to safe strapp and try it outNexesque is probably my favorite stock rom, don't why it hasn't been mentioned. It's the best debloated stock rom.
#19 Guest_BDH_*
Posted 29 June 2013 - 10:17 PM
Apparently it's not the best? LOL
- sfg likes this
Posted 29 June 2013 - 11:43 PM
I said bloated but I meant to reference that touchwiz is much like sense in that it is more resource intensive.
