Razr M, fresh out of box from asurion, running 4.1.2, i downloaded matts utility for the razr, where i successfully rooted, then unlocked, then installed cwm recovery where i made a backup, all done successfuly. Here is where i screwed the pooch... I wiped system, factory reset, cache, dalvik, all that, then installed the Rage rom. When it rebooted, it did as it had been doing everytime i rebooted since i unlocked it, showing a screen stating the phone had been unlocked and warning me of the dangers, informing me of all warranties being now null and void, and a moto website address about unlocked phones, only this time that is where it stays. It wont turn off, and i can do the vol- and power/ then vol+- and power to get to options for recovery, fastboot, etc... but when i choose fastboot or any other option it just goes back to the same your bootloader has been unlocked screen... I think what i may have done is tried to install the droid razr xt912 version of rage rom accidently because i have recently had both phones. not sure... thx in advance, you angels of android.
"I know i was born, and i know i will die, but the in between is mine..." E.V.
