912 locked out at start up
Posted 12 July 2013 - 06:36 AM
It will only show a message on start up that looks like the following:
AP SBF Flash Mode (S) (Boot Failure)
0A.77
eMMC Info: Size 16G
To return to normal mode - first press the power key to power down
Battery Low
Cannot Program
Connect USB
Data Cable
Invalid CG OTV (CG: system): Invalid SP Data
Invalid CG HAB (CG: system, status: 0X004E)
I checked the little moisture tab and it was good. Any help would be greatly appreciated. I apologize if it is a simple fix but I know very little to nothing about phones.
Posted 12 July 2013 - 07:01 AM
- Memnoch73 and rickw like this
Posted 12 July 2013 - 07:04 AM
- rickw likes this
Posted 12 July 2013 - 07:13 AM
Posted 12 July 2013 - 07:14 AM
What is telikenetically tapped? Thanks a bunch for the help. I will hopefully be able to try it today.
Johns driving and tapping his answers for you
- usmcamgrimm and johnthehillbilly like this
Posted 14 July 2013 - 07:34 AM
Posted 14 July 2013 - 07:37 AM
I did plug it in a handful of times and did not get it to charge. I used a cheap USB cord off an outlet and I tried an actual outlet charger with no luck. Is there something that is stopping it from charging?
Are you using a Motorola charger? Or motorola usb cable..... believe it or not it makes a big difference
... telekinectically tapping, tenaciously traversing the terrain...
Posted 14 July 2013 - 07:38 AM
First, cheap USB cables may work but are not reliable. I would recommend using the Moto cable. edit: John ninja'ed me
If you battery is very low, it may not be able to get the charge without using a Factory Cable/Adapter see here:
There are some Battery threads with some other suggestions that sometimes work, search the forum a bit.
Posted 14 July 2013 - 08:14 AM
Posted 04 October 2013 - 05:02 PM
my wifes phone broke recently and she needs her phone due to being home with the baby for 6+ hours a day. i need this phone now so quick responses are greatly appreciated and site donations will happen if this phone gets working i will promise that even if the government shut down. haha. i am a government employee so i can joke about it. lol. anyways i need this so please help.
so far i got to the boot menu but no charging is happening. i am using a factory vzw wall plug and thats how i get to the menu. how will i get it to 100% if it wont charge and the link says it has to be at 100%?
Posted 05 October 2013 - 08:14 AM
