Whenever I try to select anything from the boot menus this pops up:
AP Fastboot Flash Mode (S) (Boot Failure)
0A.77
eMMC Info: Size16G
Battery Low
Cannot Program
Connect USB
Data Cable
Invalid CG OTV (CG: system): Invalid SP Data
Invalid CG HAB (CG: system, status: 0X004E)
Invaild CG OTV (CG: system)
Do you know what this means?
Basically it means that ALL flashing has failed and ceased due to a low battery issue.... nothing will flash until you get some charge on the battery or you get the above mentioned factory cable or adapter.....
