Anybody ever create a zip using only there phone?
23 replies to this topic
#1 Someolddude
Someolddude
  • 426 posts
Posted 30 July 2013 - 08:01 AM
I ask because I upgraded to twrp 2500 using a zip. Fast easy just the way I like it. Want to try 2600 but as far as I know there are no Zip's for it out yet. So I thought why not use es file explorer. I extracted the meta file from the 2500 zip and put it in the same file as the 2600 IMG file. Compressed it into a zip using es and it appears to be all there like the 2500 except the zip contains the 2600 IMG. Haven't tried it yet just looking for options.
#2 LDubs
LDubs
    Pawn In Game of Life
  • 9,129 posts
  • Twitter:lew_bklyn
  • LocationBrooklyn, NY
Posted 30 July 2013 - 08:23 AM
You'd have to make it a flashable zip, not sure if there's a way to do this on phone only, but I could be wrong...
#3 jl90
jl90
    \m/
  • 1,642 posts
  • LocationPhoenix, Az.
Posted 30 July 2013 - 09:38 AM
es file explorer works i have done it that way a few times but make sure to select the "best" option for compression. i dont know if what your trying to do will work but it can be done.
#4 Someolddude
Someolddude
  • 426 posts
Posted 30 July 2013 - 11:21 AM
I only noticed one option for compression but I'll check if there's a best.
#5 BionicMan69
BionicMan69
    Android Scientist
  • 142 posts
  • Twitter:@BionicMan_69
  • LocationCookeville, TN
  • Current Device(s):Motorola Droid Razr Maxx HD, Motorola Droid Bionic, Motorola Xoom, HTC Flyer
Posted 30 July 2013 - 12:21 PM
I've done it using the Root Explorer (file manager) app and flashed them on my phone with twrp.
#6 Someolddude
Someolddude
  • 426 posts
Posted 30 July 2013 - 01:23 PM
There is a best option so I made another one. Flashed it and said successful but doesn't appear to have worked. Still says 2500 and don't look any different. At least I didn't break my phone lol.
#7 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 30 July 2013 - 02:04 PM
I would suggest staying away from anything that isn't ready for "prime time" as usually there are reasons(bugs) that may be unknown but may have unforeseen(bad) consequences.
#8 Someolddude
Someolddude
  • 426 posts
Posted 30 July 2013 - 02:12 PM
It is experimental so probably for the best at this point.
#9 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 30 July 2013 - 06:44 PM
There is a flashable TWRP 2.6:
#10 Someolddude
Someolddude
  • 426 posts
Posted 31 July 2013 - 03:23 AM
I'll have to check that out. I have found a few but they were all for something other than xt907 and I don't want to take a chance with that.
#11 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 31 July 2013 - 08:52 AM
No worries.  That's actually the one I used to upgrade to 2.6.  I whole-heartedly trust the stuff on Batakang.
  • Someolddude likes this
#12 Someolddude
Someolddude
  • 426 posts
Posted 31 July 2013 - 01:23 PM
It worked thanks. Wonder if the zip name was the problem. They both look exactly the same except for that. Even both the same exact mb size. All the options look the same while in recovery. After flashing mine out was successfully bit still said 2500. But I noticed a side load option that I didn't remember 2500 having.
#13 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 31 July 2013 - 01:40 PM
Also, instead of the button for naming your backup being near the bottom right, it's now at the top center of the screen.
#14 Someolddude
Someolddude
  • 426 posts
Posted 31 July 2013 - 06:28 PM
Noticed that today and also the encription.
#15 Someolddude
Someolddude
  • 426 posts
Posted 01 August 2013 - 08:06 AM
Mine reverted back to 2.5.0.0. That's odd. Noticed it last night I'll have to flash again and see what happens.
#16 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 01 August 2013 - 09:07 AM
That's definitely weird.  Mine has 2.6.0.0 on top.
#17 Someolddude
Someolddude
  • 426 posts
Posted 02 August 2013 - 01:42 PM
I just went into recovery to reflash 2600 and its already 2600??? I'm positive it was 2500 last I checked and didn't have the encription option. Perhaps I was hallucinating.
#18 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 02 August 2013 - 02:00 PM
You need to tell me what you've been taking.  It sounds good. ;)
#19 kyle1329
kyle1329
  • 19 posts
  • LocationMPLS , MN
  • Current Device(s):VZW XT907 Droid RaZr M
Posted 08 September 2013 - 04:38 PM
ZIPme is a free a app on the Play Store made by the same guy that makes ROM Toolbox. it allows you to take and file and turn it into a zip file all the while not to boot into recovery until you install the zip file you created.
#20 Someolddude
Someolddude
  • 426 posts
Posted 08 September 2013 - 06:01 PM
I'll have to check that out might come in handy.
