CM 10.2 Android 4.3
Posted 31 July 2013 - 11:06 AM
Sent from my XT926 using Xparent Purple Tapatalk 2
Posted 31 July 2013 - 11:42 AM
LINK?
Posted 31 July 2013 - 11:48 AM
I am surprised this ROM is not listed on droidrzr. Daily driver ready. Everything works. Found over on xda but I prefer coming here for discussions, support, etc.
It's up to the dev where he wants to post it, but here's a little help. Nothing in there for the 912, though.
Posted 31 July 2013 - 02:59 PM
You can discuss it here. You can also build the rom yourself? That's what I'm gonna do. It's up to them to post it here. Once I finish compiling it, I can ask If I can post it here.
- shane1 likes this
Posted 31 July 2013 - 04:31 PM
Posted 31 July 2013 - 04:45 PM
I looked to see if I could do a 912 but they didn't have a manifest for it yet. And my skills are VERY limited. Sorry
Posted 31 July 2013 - 04:46 PM
Can not gain my root privilages with this rom.. any help?
Posted 31 July 2013 - 04:59 PM
people have said theres flakey stuff going on with 4.3. It was my understanding that "SuperSu" was supposed to work with 4.3. Chainfire was the first to gain root on it.
Perhaps try to reroot your phone in recovery with
. Download, place on SD card and flash in recovery.
Posted 31 July 2013 - 05:32 PM
What tucstwo said. Flash su in recovery.
Posted 31 July 2013 - 05:34 PM
Yeah, I know it's up to the Dev, I was just surprised. And this was at least my way to let others know in case some didn't look other places.
- RikRong likes this
Posted 31 July 2013 - 06:16 PM
thank you. It didn't work. when I tried to flash using twrp, it fails every time..
Posted 31 July 2013 - 06:54 PM
I had no issues flashing in TWRP 2.5.0.0 so perhaps bad download? I've also seen some suggest that you can simply go into developer options and change Root Access from "apps only" to "apps and adb" then back to "apps only" and maybe reboot after to wake it back up. I had already flashed the zip successfully before trying that so I cannot personally say if it works or not and would appreciate confirmation from someone who has not yet rooted 10.2
Posted 31 July 2013 - 07:01 PM
FWIW, TWRP 2.6.0.0 is out for both devices. and it ALWAYS works on my phone.
Please flash and use the latest recovery for your device.
Posted 31 July 2013 - 08:04 PM
Posted 31 July 2013 - 08:45 PM
You will have to flash the supersu zip if using twrp if you use either of the recoveries that dhacker posted earlier it will work without flashing the zip.
Posted 31 July 2013 - 09:15 PM
Enable it in developer options
sent from my xt926 RAZR maxx hd
Posted 31 July 2013 - 09:35 PM
Had no idea. Thanks man!
Posted 02 August 2013 - 10:11 AM
So how is the notifications with this rom? i've tried almost every rom out there and I've always found myself reverting to stock because of constant issues with my notifcations, battery draining, and freezes.
Posted 02 August 2013 - 10:37 AM
No issues for me, but I've never had issues outside of minor ones with Halo on liquidsmooth (and only then when trying to open two resource intensive apps simultaneously)
Posted 02 August 2013 - 05:23 PM
