RAZR Maxx won't flash
Posted 02 August 2013 - 08:43 AM
Posted 02 August 2013 - 08:50 AM
Sent from my DROID RAZR using Tapatalk 4 Beta
Posted 02 August 2013 - 09:04 AM
If that does not work you may have to backup and format internal storage then run Matt's utility (option 1) to " nuke and repave" .....
... telekinetically tapped, tenaciously traversing the terrain ...
Posted 02 August 2013 - 09:11 AM
Posted 02 August 2013 - 09:31 AM
I have everything backed up with titanium so no problem to wipe it. Will I need to root again after wiping? I have already reinstalled SS once but I didn't erase the backup that I made with SS but I wouldn't think that would cause an issue. Maybe in assuming too much...
You will have to root again and reinstall SS
Posted 02 August 2013 - 09:32 AM
Posted 02 August 2013 - 09:56 AM
Posted 02 August 2013 - 10:00 AM
Posted 02 August 2013 - 10:03 AM
Posted 02 August 2013 - 10:08 AM
In case you don't know, titanium does not back up your storages.... that has to be done manually....
Posted 02 August 2013 - 10:15 AM
Posted 02 August 2013 - 10:17 AM
Posted 02 August 2013 - 10:33 AM
Posted 02 August 2013 - 05:46 PM
Looks like Matt's utility is my only option at this point. It's just weird that it says it can't open the .zip file.
Agreed....
Try a diffierent sd car
Posted 02 August 2013 - 06:02 PM
Posted 02 August 2013 - 08:14 PM
Ok, I did a factory reset/data wipe then I used Matt's utility with option 1. then 3. I installed SS again and long story short, nothing changed, FAILED. Now what????
Posted 03 August 2013 - 06:57 AM
well if the hash was good and you dont have a corrupt file, it seems like the only thing I havent seen tried is a different sdcard......
Posted 03 August 2013 - 07:26 AM
