as far as the "old" stuff on sdcard0 (internal) you can(should) backup then format the internal storage whenever you run the utility to wipe the entire phone....... any "leftover" files on internal storage will have a direct impact on current installations ...... if you are not clear on how to backup and format internal storage you can follow the directions
RAZR Maxx won't flash
#22
Posted 03 August 2013 - 08:41 AM
Sent from my DROID RAZR using Tapatalk 4 Beta
#23
Posted 03 August 2013 - 08:46 AM
Not sure why I didn't think of that. I'm wondering if just doing this and only having SS on the internal would do the trick without having to use Matt's utility again? I guess it wouldn't hurt to give it a try would it?
there may be "hidden" and or unseen files still sitting on the internal storage wiping the internal should completely take care of them
#24
Posted 03 August 2013 - 03:57 PM
Ok, so I transfered my internal storage and formatted it and just to be safe I reinstalled SS from the .apk from the ext sdcard. I then rebooted, entered Recovery, Created Slot 1, then wiped System, Cache, Dalvik Cache, and Factory reset, in that order. Try to flash Rage to Slot 1, E: unable to open the .zip file so I tried Blurry, same error so on to Aviator, same. I was beginning to think that it was something that I was doing wrong. I now think that it is something that someone much smarter than myself is going to have to figure out how to do it. I know that it can't be impossible or can it? I just want to get away from the Stock ROM so please keep the help coming...
#25
Posted 03 August 2013 - 05:02 PM
How are you getting the zip onto the sdcard? When you stated earlier that you validate the md5, are you doing that on your PC?
If the answers are from the pc via a USB cable, and you check the md5 on the pc prior to transfer, I have to guess that something is wrong in the transfer.
I would try to d/l the zip directly on the phone.
I am running out of suggestions.....
#26
Posted 03 August 2013 - 05:12 PM
#27
Posted 03 August 2013 - 05:29 PM
since SafeStrap can see the internal for flashing the zip, maybe try that....
#28
Posted 03 August 2013 - 05:31 PM
also can we assume you have the latest SS which would be 3.11 for you
#29
Posted 03 August 2013 - 05:42 PM
re-read one of your posts....do you ever activate the slot you created?
#30
#31
Posted 03 August 2013 - 05:43 PM
#32
Posted 04 August 2013 - 01:06 PM
#33
Posted 04 August 2013 - 01:22 PM
UNCLE......Sorry I dont think I have anything left. Very odd issue.
#34
Posted 04 August 2013 - 01:25 PM
#35
Posted 04 August 2013 - 01:35 PM
... telekinetically tapped, tenaciously traversing the terrain ...
#36
Posted 04 August 2013 - 01:49 PM
Sent from my SCH-I545 using Tapatalk 4 Beta
#37
Posted 04 August 2013 - 02:04 PM
#38
Posted 04 August 2013 - 02:12 PM
#39
Posted 04 August 2013 - 02:28 PM
#40
Posted 05 August 2013 - 08:02 PM
