Phone want turn on.
Best Answer Stranger45 , 07 August 2013 - 06:31 AM
Had a bad sims card, Verizon replaced it, all good now.
Thanks all for you help.
Go to the full post
16 replies to this topic
#1 Stranger45
Stranger45
  • 10 posts
Posted 05 August 2013 - 12:21 PM
As you all can guess I have a problem with my phone. I have a Razr Maxx that my nephew gave me that he tried to root, and it's been a while, and he can not remember what he did. The only thing I can tell you is that it's from Verizon, and I can get into recovery utility, apply update from external storage, ect. It has something on it called Arctic_HD_0.10.zip, when I ran it earlier I could get the phone to come on, and get into all it functions, but could not get any data service. So can anyone help, I know you will need more info just ask. Also I have tried following some of the links on here and other sites, but not having any luck.
#2 Alex.Abraham
Alex.Abraham
  • 477 posts
  • Twitter:aabraham123456
  • LocationNew Jersey
Posted 05 August 2013 - 12:35 PM
Did you try running Matt's Utility and restoring back to stock? Thats probably the best way to go
#3 cmh714
Posted 05 August 2013 - 12:37 PM
You are probably going to need to start over and use Matts utility as Alex said....
Here:
#4 Stranger45
Stranger45
  • 10 posts
Posted 05 August 2013 - 12:51 PM
Is this Matt's Utility your talking about?
If so what, and where do I find what I need to restore back to stock?
#5 cmh714
Posted 05 August 2013 - 01:03 PM
Yes Matts site has the utilities as well. Get the one for your device and follow the directions to get your self back to stock. Then if you want you can also use it to get root, install safestrap and from there well your back and ready to install custom rom's.
The utility has everything you should need.
#6 Stranger45
Stranger45
  • 10 posts
Posted 05 August 2013 - 01:23 PM
Will the utility download to my computer, or phone? So far all I have downloaded is a toolbar.
#7 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 05 August 2013 - 01:47 PM
You need it downloaded to the PC
#8 Stranger45
Stranger45
  • 10 posts
Posted 05 August 2013 - 02:21 PM
 I think  I have it now.
#9 Stranger45
Stranger45
  • 10 posts
Posted 05 August 2013 - 02:56 PM
I have it all downloaded, what file do I need to run?
#10 johnthehillbilly
Posted 05 August 2013 - 03:17 PM
Extract to desktop..... if on windows, install Motorola drivers and run the .bat file...... if in Linux or Mac, run the .sh file :)
... telekinetically tapped, tenaciously traversing the terrain ...
#11 Stranger45
Stranger45
  • 10 posts
Posted 05 August 2013 - 04:33 PM
I got everything except a data signal, what did I do wrong?  Also can't rest the phone with my phone number.
#12 livinginkaos
Posted 05 August 2013 - 05:09 PM
Try powrting off, pull the sim, power on and let it boot completely, power off, insert sim and power on.
From My S4 Dev Edition
#13 Stranger45
Stranger45
  • 10 posts
Posted 05 August 2013 - 05:32 PM
Sill no data signal, anymore ideas?
#14 cmh714
Posted 05 August 2013 - 05:39 PM
You can try changing settings in the test menu....
enter *#*#4636#*#* in the dialer
you can then try and change your network type and see if that fixes it
#15 Stranger45
Stranger45
  • 10 posts
Posted 05 August 2013 - 06:11 PM
What should the network type be?
#16 robocuff
robocuff
  • 415 posts
Posted 06 August 2013 - 05:57 PM
Change it to GSM only.  You'll see the screen flash, or sort of anyway, then change it to LTE/CDMA auto (PRL).  Then give it a little time and see if it connects.
#17 Stranger45
Stranger45
  • 10 posts
Posted 07 August 2013 - 06:31 AM   Best Answer
  • johnthehillbilly likes this
