Nexus 4 battery life
Battery Nexus 4 Data Usage
21 replies to this topic
#21 johnthehillbilly
Posted 08 August 2013 - 10:07 AM
Yes sir
ha ha .... non brutis .... iustus trying ut ridiculam lol
(Hopefully I got that right, Latin is not a strong point for me)
"... try not... do or do not! .... there is no try ... "
#22 26jozy
26jozy
  • 9 posts
  • LocationFL
  • Current Device(s):Nexus 4
Posted 08 August 2013 - 12:05 PM
Also... the battery meter may not be entirely accurate and may need recalibrated.... To do this, run the device u till the battery is depleted.... then plug into a wall charger (leave it off) then let charge to 100% then about 1/2 hour or so longer..... then unplug and power on..... repeat if desired ... your battery should then be calibrated..... ... telekinetically tapped, tenaciously traversing the terrain ...
   Ahem... So after charging the phone on off mode and leaving it an extra 30min to re calibrate the battery this is what I get... nada
nothing changed I turned it on for 15 min and as I'm changing my wallpaper and looking at text that came in BLOOP it turned off  :mellow: but at least my wallpaper stayed ... spoke to soon second time it went BLOOP no more wallpaper... I'm starting to think the Pic I have is the reason.. its coming from my back up pic not from the phone gallery... hmmm
As far as your issue tho... Does anything else reset upon reboot? And what rom are you using? Stock? Custom?
 guess what else reset though... the sound it makes when you tap on the screen...I had it on silent... now I hear the  tchick!   :unsure:
Any other suggestions ?
  100.69KB   1 downloads
01100011011010010110000101101111
Also tagged with one or more of these keywords: Battery, Nexus 4, Data Usage
