Hi all, just wondering on the process for this before I get started.
So I'm going to be, well, all of the above, (eg. Rooting, unlocking BL, installing TWRS, and finally flashing
I am planning to use Mattlgroff's utility for the XT907, which will work for this, of course.
So, first things first;
- THE SYSTEM VERSION ON THE DEVICE IS 98.18.78, HOWEVER, FOR FlyingJelly IT IS LISTED AS 98.15.66. Will this work?
- I recently rooted my RAZR (XT912, that is, but my brother does own the XT907), and I had to factory reset in order to get the exploit to work. (I used RAZR Blade for the XT912, of course). Does anyone know if I have to factory reset with Hashcode's as well?
- Next I will be unlocking the bootloader. Anything I should be scared of here? I of course couldn't do this with my XT912, so this is a bit new to me. Is there anything at all that I have to do before I use the utility to unlock the BL? Remember, I will [hopefully] have root before this.
- Now I will be installing TWRP (also the one from the utility). I did this [with SafeStrap] on my XT912 (which is based off of TWRP), but again, there's nothing I should look out for?
- Alrighty, and lastly, I will be installing some ROM (please leave suggestions for STABLE ROMs, he won't like having to flash new versions or having problems with something) and then, if it is not included, Gapps. I would imagine that this is very similar, if not identical to how it works with SafeStrap, as in, I create a ROM Slot, and then flash to that. Correct?
Anyways, any help would be greatly appreciated. I'll keep browsing the forum and Chat Room for some help, as I'd bet most of these are answered.
Thanks,
staMerrill
