Posted 13 June 2012 - 12:12 PM
Posted 13 June 2012 - 12:16 PM
Posted 13 June 2012 - 12:29 PM
Posted 13 June 2012 - 12:30 PM
Posted 13 June 2012 - 12:39 PM
Posted 13 June 2012 - 12:41 PM
Go here
thats all you need
if you go back to safeboot menu and toggle you should boot into stock
Posted 13 June 2012 - 12:42 PM
Posted 13 June 2012 - 12:43 PM
You need a rom to flash
thats all you need
^THIS.
I was just about to ask him if he had swapped to safe mode and not flashed a ROM.
Posted 13 June 2012 - 12:45 PM
Posted 13 June 2012 - 12:48 PM
Posted 13 June 2012 - 12:51 PM
#14 Guest_BDH_*
Posted 13 June 2012 - 12:53 PM
Yes it does say safe system enabled. The problem is when I press anything else like search screen goes black or menu to get to the menu the little logo with the hat shows up very dim. I downloaded the link wyld gave me but like I said computer wont recognize device so it wont recognize it.
With safe system enabled, have you flashed anything on it? When you enable safe system, it essentially partitions your phone so to speak. So when you try to boot up after enabling safe system, if there's no OS, you'll just get a black screen.
Posted 13 June 2012 - 12:55 PM
Posted 13 June 2012 - 12:57 PM
Posted 13 June 2012 - 01:01 PM
Use the volume keys to move up and down and the power button to select.
Posted 13 June 2012 - 01:08 PM
Posted 13 June 2012 - 01:11 PM
Posted 13 June 2012 - 01:19 PM
Reboot back to the safestrap menu and toggle your safe system. Reboot and see if it boots up.
How do I toggle the safe system?
Do not select quick toggle.
Also tagged with one or more of these keywords: brick, razr, bricked
