#21
Posted 13 June 2012 - 01:31 PM
#22
Posted 13 June 2012 - 01:37 PM
#23
Posted 13 June 2012 - 01:38 PM
#24
Posted 13 June 2012 - 01:42 PM
#25
Posted 13 June 2012 - 02:11 PM
#26
Posted 13 June 2012 - 02:53 PM
#27
Posted 13 June 2012 - 03:21 PM
#28
Posted 13 June 2012 - 03:46 PM
#29
Posted 13 June 2012 - 03:48 PM
Power down the phone and reboot. There will be a safe boot menu in safestrap. Use the volume down key to highlite it and hit the power button to select. On the screen that comes up next, scroll down to yes and hit the power button. This toggles between your real system and the safe system.How Do I untoggle safestrap? The menu doesnt show up when I hit the menu button to go there
If you can't use it though, these instructions are moot lol
#30
Posted 13 June 2012 - 03:49 PM
Now that you mention it I believe I did format the system while in safestrap...
I hope you did that with safe system ENABLED
#31
Posted 13 June 2012 - 04:05 PM
read it twice and look at the video til you fully understand
#32
Posted 13 June 2012 - 04:28 PM
#33
Posted 13 June 2012 - 05:00 PM
Your phone is connected to a USB port while checking that? There is an ADB listed with a MOT composite interface? or is nothing listed at all?Ok so I understand...Problem is I install the link it gives but Mot Single ADB Interface isnt appearing in device manager...
#34
Posted 13 June 2012 - 05:39 PM
#35
Posted 13 June 2012 - 05:43 PM
#36
Posted 14 June 2012 - 05:51 PM
#37
Posted 14 June 2012 - 07:57 PM
#38
Posted 14 June 2012 - 08:46 PM
#39
Posted 15 June 2012 - 03:57 AM
Hi guys sorry about the late response. I tried for literally 7 hours straight and nothing. zero zip natta. So I called Verizon and they sent me a refurb...I truly appreciate all your help, I HATE HATE HATE giving up like that, but i felt as if I had no choice. Again thanks for all your guys's help! This is a great forum, Ill be checking it our frequently!! Thanks for the PM too Zachjeep.
Sorry bout that but please don't give up. If you're going to install safestrap again just make sure you're in safe system ENABLED when wiping and formatting. Make a backup before you do... on the UNSAFE side enabled first!
I prefer bootstrap. But never messed with safestrap
I like safestrap for the convenience of being able to move back and forth from the original to whatever custom ROM is installed. Also much easier IMO to put right whatever may get messed up in the process. Also for the ease of updating the original with an OTA if I choose.... but that's just me.
#40
Posted 15 June 2012 - 08:31 AM
Also tagged with one or more of these keywords: brick, razr, bricked
