I have been having a problem lately where TWRP stopped prompting for a password to decrypt storage. Initially when I encrypted the device it would prompt for a password, but now it wont. I'm currently running XeononHD 8-6-13 and using 2.6.0 TWRP as a recovery. I have already re-flashed TWRP from a different source and that didn't seem to fix it. Has anyone else experienced this issue?
2 replies to this topic
Posted 25 August 2013 - 03:21 PM
Posted 26 August 2013 - 05:50 AM
Hey ghost i had this problem about a month back but from other causes. Reformat your internalsd under wipe format data then under advanced make sure permissions are fixed. At this point if you go into mount in twrp you should be able to click data. If so your all set!
Posted 27 August 2013 - 08:10 PM
I don't know if it was clear before, but I have the device encrypted. Wouldn't formatting the internal sd wipe system and data, or am I missing something?
Also tagged with one or more of these keywords: TWRP
