unlock/recovery/reboot issues from the noob
unlock bootloader root recovery flash
170 replies to this topic
#1 mdpatterson
mdpatterson
  • 81 posts
Posted 26 August 2013 - 11:08 AM
I am totally new to this and learning as I go. I am pretty sure I successfully rooted my droid
maxx hd xt926 4.1.2 JB. the root checker and connectbot app confirm the root and the SU app is installed. I am trying to install
because as I understand it, that will allow me to get into the more serious customizations that I want to do. I have learned that in order to do so, I have to unlock the bootloader and flash the recovery. Both of these things I have been working at extrenuously to no avail. I downloaded and ran Matts Utility with no success, my phone still says locked on the boot screen. I have tried several other methods as well. I am sure that I have not provided valuable info to give a good picture of what needs to be done, but I am home all day and can provide any info needed to anyone that is willing to help me out. what is the best forum to address this issue in?
version 9.16.6xt926
#2 cmh714
Posted 26 August 2013 - 11:34 AM
You found the correct forum, you just now need to do some reading in here....whether you can unlock the bootloader depends on what specific version you have, and that info can be found in Settings - About Phone. Post a screen shot is easiest or post the info back in here.
  • mdpatterson likes this
#3 mdpatterson
mdpatterson
  • 81 posts
Posted 26 August 2013 - 11:38 AM
yes its system version 9.16.6xt926 and android version 4.1.2
#4 cmh714
Posted 26 August 2013 - 11:59 AM
also post the build number md......
I think as long as you havent taken the .20 update you can still unlock, but not 100% sure.
I need to learn the HD a little better. :)
#5 cmh714
Posted 26 August 2013 - 12:00 PM
Whatevr you do, DO NOT TAKE ANY UPDATES YET
#6 mdpatterson
mdpatterson
  • 81 posts
Posted 26 August 2013 - 12:01 PM
build number is 9.8.1Q-62_VQW_MR-2
#7 cmh714
Posted 26 August 2013 - 12:06 PM
Like I said, I am not as good with this device as I am on the one I have now....but I think you need this: EDIT: link deleted
If your nervous, just wait for one of the others to post. You can trust SamuraiHL, Johnthehillbilly, livinginkaos, and Memnoch amongst others (no one flame me for not including you here )
  • johnthehillbilly likes this
#8 mdpatterson
mdpatterson
  • 81 posts
Posted 26 August 2013 - 12:12 PM
ill check it out......but my phone just started wigging out.....keeps rebooting almost....says "unfortunately, the process com.motorola.process.system has stopped" it does that about 5 or 6 times, then tries to completely reboot, and ends up on the ap fastboot screen and stops there......freaky deaky
#9 cmh714
Posted 26 August 2013 - 12:14 PM
try wiping cache and dalvik to fix that
#10 mdpatterson
mdpatterson
  • 81 posts
Posted 26 August 2013 - 12:15 PM
I would if It would stay on long enough....
#11 cmh714
Posted 26 August 2013 - 12:16 PM
you can do it from Recovery
#12 mdpatterson
mdpatterson
  • 81 posts
Posted 26 August 2013 - 12:18 PM
awesome, ill give it a whirl when it gets there again. you guys are saints here.....this droid woke up this morning solely intent on getting under my skin
#13 mdpatterson
mdpatterson
  • 81 posts
Posted 26 August 2013 - 12:20 PM
yeah it wont go to recovery. it just goes to the "device is locked" screen and says "failed to hab check for recovery: 0x56
fastboot reason: boot failure
#14 mdpatterson
mdpatterson
  • 81 posts
Posted 26 August 2013 - 12:24 PM
hopefully between here and youtube videos I can fix it
#15 cmh714
Posted 26 August 2013 - 12:29 PM
So first be careful with YouTube videos...we've seen some way bad ones.
Since I dont want to give you bad advice, you should wait for one of the others to respond...which of Matts utilities did you use?
#16 mdpatterson
mdpatterson
  • 81 posts
Posted 26 August 2013 - 12:30 PM
1.21
#17 cmh714
Posted 26 August 2013 - 12:48 PM
Well thats the correct utility and I believe it has the same version you have.....
#18 mdpatterson
mdpatterson
  • 81 posts
Posted 26 August 2013 - 12:49 PM
yeah im trying to wipe my phone completely now to stop this infernal rebooting. but no luck
#19 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 26 August 2013 - 12:51 PM
Go back into fastboot and run the Utility again
#20 cmh714
Posted 26 August 2013 - 12:52 PM
Ahh, some support at last! Thx Memnoch, I was pretty sure thats what he was gonna need but didnt want to goof him up before he gets unlocked.
EDIT: DANG 1500 post mark....you would think I should know all the devices by now :)
  • Memnoch73, Gytole and johnthehillbilly like this
Also tagged with one or more of these keywords: unlock, bootloader, root, recovery, flash
