(SOLVED!!) There was no visible dirt in the port after many inspections, but just for good measure I got a piece of thick stranded speaker wire and combed out the charging port several times and air compressed it after. It charges now!! There is still no visible change in the port but I tried both before and after the cleaning and everything is working now. Thanks for your replies!
Ok. So after searching google for an hour on this, I can't seem to find an answer.
I have the droid razr maxx. It's got safestrap and is rooted.
The problem is that it will only charge from a computer's USB port, not the wall charger that was included by motorola. The same adapter that WON'T charge my phone will charge my friend's phone just fine through the exact same cable. I try putting my phone into his brand new samsung S4 charger, nothing.
At first I thought the issue was with the charger, but obviously not. Then I thought why not factory reset it using fastboot? Still nothing. There doesn't seem to be anything in the port either.
Any help would be awesome folks, thanks.
