Unable to mount
20 replies to this topic
#1 dkash
dkash
  • 12 posts
Posted 02 September 2013 - 08:48 PM
So when I try to wipe and flash it tells me that it is unable to mount, and when flashing it says no md5 file found. I am new to this, so hopefully it is just something simple. I rooted my phone, and am using safestrap 3.5. Any ideas? Thanks!
#2 johnthehillbilly
Posted 03 September 2013 - 02:47 AM
Ok.... what are you trying to flash? .... have you created a ROM slot (for flashing ROMs).....
  • jl90 likes this
#3 dkash
dkash
  • 12 posts
Posted 03 September 2013 - 04:44 AM
I did create a ROM slot in slot 1, and I am trying to flash the most recent cyanogenmod cm-10.2-20130902-NIGHTLY-spyder.zip with the gapps that are for 10.2. When I try and do it, safestrap says in the log that it was unable to mount
#4 dkash
dkash
  • 12 posts
Posted 03 September 2013 - 05:37 AM
I think it may have something to do with safestrap. How can i completely remove it and reinstall it? I have tried to delete it through my apps, but it is still there when I boot up.
Nevermind I got it, I forgot to uninstall the recovery first
  • cmh714 likes this
#5 dkash
dkash
  • 12 posts
Posted 03 September 2013 - 07:43 AM
So I still don't have this working. I think my problem is that even though it says it is successfully creating a tom slot....its not. I keep getting the unable to mount in the log.
#6 johnthehillbilly
Posted 03 September 2013 - 08:36 AM
You may have a bad ROM zip.... try redownloading it...... also are you plugged into computer ?..... (sometimes this will have negative effects on mounting)..... also.... you may want to double check proper root access on stock.....
#7 johnthehillbilly
Posted 03 September 2013 - 08:37 AM
May have to go back to SS 3.11
#8 dkash
dkash
  • 12 posts
Posted 03 September 2013 - 09:44 AM
I tried doing that, but I had no luck. Does my phone need to be plugged into the computer when I try and create a ROM, and then flash onto it? I also downloaded the file again, and I have the gapps and cyanogenmod both in a folder on my external SD called downloads, still in their zipped format, I just dragged and dropped.
#9 johnthehillbilly
Posted 03 September 2013 - 09:46 AM
No... you should be unplugged from computer.... take the zip files out of the "downloaded" folder and place then on the "root" of external.....(sdcard) that could be the issue ....
#10 dkash
dkash
  • 12 posts
Posted 03 September 2013 - 10:10 AM
I am still having the unable to mount issue. When I try to factory reset rom-slot1 before I flash it, it reads E:Unable to mount '/system' E:Unable to mount '/data' E:Unable to mount '/cache'
 E:Unable to mount '/osh'
#11 OldBaldy
OldBaldy
  • 425 posts
  • LocationSouth Carolina
Posted 03 September 2013 - 11:58 AM
What version of safestrap are you using, and are you sure it's for the spyder (xt912)?
#12 dkash
dkash
  • 12 posts
Posted 03 September 2013 - 12:59 PM
I am using safestrap 3.50
#13 johnthehillbilly
Posted 03 September 2013 - 01:02 PM
Double check make sure you have the spyder version..... maybe redownload SS 3.5 and reinstall
#14 cmh714
Posted 03 September 2013 - 01:57 PM
Thats the newest one and it still has issues, Get the stable one:
  • johnthehillbilly likes this
#15 dkash
dkash
  • 12 posts
Posted 03 September 2013 - 02:27 PM
I think you all may be on to something! I am creating a new ROM slot now, and it seems to be working correctly, I will fill you in more when that finishes and I attempt to flash it >.<
#16 OldBaldy
OldBaldy
  • 425 posts
Posted 03 September 2013 - 02:28 PM
Just ran a test wiping and restoring my slot 3 and SS3.50 works perfectly. This is the md5 of the file I downloaded form the safestrap thread on this site.
f6860e2da152d8e2fe4ccb984bd68656
Sent from my DROID RAZR using Tapatalk 4
  • johnthehillbilly and cmh714 like this
#17 dkash
dkash
  • 12 posts
Posted 03 September 2013 - 02:46 PM
Okay, so I got it all to work, but now the WiFi doesn't work >.< I am using the most recent cyanogenmod released, and gapps for 10.2, should i reflash it with the most recent stable mod which is 10.1.2, and use the gapps for 10.1?
#18 dkash
dkash
  • 12 posts
Posted 03 September 2013 - 03:03 PM
Okay, I think I actually got it all to work on 4.3. Thank you everyone for your assistance it was all greatly appreciated. You all must know what it's like to have a non working phone, because everyone was quick to help!
  • johnthehillbilly and dbReed53 like this
#19 johnthehillbilly
Posted 03 September 2013 - 03:45 PM
You're welcome :) .... yes most of us know what its like to have a borked phone :)
Glad you got it :)
#20 aaron_escoto
aaron_escoto
  • Current Device(s):Droid Razr Maxx XT912
Posted 29 October 2013 - 02:00 PM
What did you do that fixed this? I'm have the same problem on my XT912, with safestrap 3.60, and CM 10.1.3. I keep getting
E:Unable to mount 'osh'.
