Framework Nightmare!
Posted 18 June 2012 - 06:40 AM
Posted 18 June 2012 - 07:03 AM
I am not really seeing much different from the the gnexus. There are a handful of Motorola images but everything else is the same.
gonna be pretty hard to replace the wifi/signal/data pngs. ive tried and they overlap each other.
#4 Guest_R3Ds_*
Posted 18 June 2012 - 07:13 AM
R3Ds Themes
Posted 18 June 2012 - 07:16 AM
#6 Guest_R3Ds_*
Posted 18 June 2012 - 07:42 AM
R3Ds Themes
Posted 18 June 2012 - 07:50 AM
Posted 18 June 2012 - 07:57 AM
Are you basically saying you don't share your work?. If so I have to say I wouldnt be so willing to help ya even if I did know how to theme. Android is a community to share knowledge and continue the progression of the OS. Just my opinion
Posted 18 June 2012 - 08:03 AM
By saying you are a private themer....
yes i make themes for myself and "ocassionaly" share. i wasn't asking for help, i was stating how the framework was. and i stopped sharing becuase android fans are greedy, hence why i don't go to xda anymore. and if you read what i typed im sharing how i tried to deodex this rom for us. if i would of achieved it, i would of shared that.
Posted 18 June 2012 - 08:55 AM
yes i make themes for myself and "ocassionaly" share. i wasn't asking for help, i was stating how the framework was. and i stopped sharing becuase android fans are greedy, hence why i don't go to xda anymore. and if you read what i typed im sharing how i tried to deodex this rom for us. if i would of achieved it, i would have shared that.
FTFY
Posted 18 June 2012 - 09:46 AM
#12 Guest_BDH_*
Posted 18 June 2012 - 09:59 AM
yeah i give up, ive tried to replace and resize the data/signal/wifi png's and they just overlap each other. not thrilled with how moto set this up at all. im thinking there needs to be some sort of xml edits done.
Those icons are the same on every ICS build. It's not Moto that did it, it's Android. Also, the SystemUI has an odex file which means you're not changing anything until that's deodexed.
Posted 18 June 2012 - 10:04 AM
nope not true everything can be changed minus adding a accurate battery % mod. i know as 90% of my stock rom is now themed without deodexing anything. and for the razr those icons may be universal but not on every ics rom for every phone. im mostly talking about the shape of the wifi/signal/data png's.
#14 Guest_BDH_*
Posted 18 June 2012 - 10:06 AM
Every official ICS will have those. If you can successfully decompile the SystemUI then you can do the 1% mod. It's just editing 2 XML files.
Posted 18 June 2012 - 10:08 AM
Posted 18 June 2012 - 10:10 AM
The one percent mod also requires editing the services.jar. if the images and xmls are edited without editing the services.jar you will most likely still be able to boot. However you will only see the increments in which services.jar allows.
I will add however... with the overlapping check the xmls for the status bar. Compare them to an aosp build. Im sure you will find differences. Use diff to pick them apart to see where the changes are.
Posted 18 June 2012 - 10:12 AM
as of now it has mods to:
dialer
lockscreen
blacked out menus
statusbar icons
stock gnexus ics battery
etc..
* this was only tested on bootstrap.
Posted 18 June 2012 - 10:13 AM
yup it's more than just editing the framework.res & systemui.
#19 Guest_BDH_*
Posted 18 June 2012 - 10:14 AM
I know how to theme lol. The 1% mod has nothing to do with the framework-res btw.
- fixxxer2012 likes this
Posted 18 June 2012 - 10:16 AM
