[ Rom-Ics ] Ikream.ics.6.16.2.15.rom.v2.4-R3Ds
Posted 19 June 2012 - 12:06 PM
Posted 19 June 2012 - 12:09 PM
It comes tomorrow though :-)
Sent from my ADR6400L using Tapatalk 2
Posted 19 June 2012 - 12:43 PM
- decentralize and fixxxer2012 like this
#5 Guest_R3Ds_*
Posted 19 June 2012 - 03:34 PM
Yes, ikream the other one was stock for devs to use. I'm posting links in a fewis this different from the one you posted in my thread earlier?
R3Ds Themes
Posted 19 June 2012 - 04:00 PM
#7 Guest_R3Ds_*
Posted 19 June 2012 - 05:02 PM
#8 Guest_R3Ds_*
Posted 19 June 2012 - 05:10 PM
#9 Guest_R3Ds_*
Posted 19 June 2012 - 05:21 PM
#10 Guest_R3Ds_*
Posted 19 June 2012 - 05:22 PM
yes, and links are upLink? I so wanna flash this!!! Is it themed as well?
Posted 19 June 2012 - 07:12 PM
#12 Guest_BDH_*
Posted 19 June 2012 - 07:52 PM
So what does the UI mod do exactly? I flashed it, and unfortunately didn't have a status bar at the top anymore. I also flashed directly after flashing rom without a bootup. So most likely my fault.
Reboot the ROM normally, wipe cache and dalvik, reflash, reboot. Should be good.
Posted 19 June 2012 - 11:46 PM
Thanks again for great job man
Posted 20 June 2012 - 02:45 AM
Sent from my DROID RAZR using Xparent ICS Blue Tapatalk 2
Posted 20 June 2012 - 02:49 AM
Can this be flashed from 181?
You will have to get to atleast the .79 ICS leak and install the ICS safestrap 2.0 and than install this on safe side. If you need help feel free to PM me.
Posted 20 June 2012 - 06:38 AM
ThanksYou will have to get to atleast the .79 ICS leak and install the ICS safestrap 2.0 and than install this on safe side. If you need help feel free to PM me.
Posted 20 June 2012 - 12:05 PM
Posted 20 June 2012 - 08:32 PM
Posted 21 June 2012 - 06:48 AM
Posted 21 June 2012 - 06:52 AM
no gapps falsh required correct?
Nope all included
- islandfever likes this
