(Noob Alert) The FXZ meaning the entire package? Which folder should i place it under?
This is a point that many get wrong so please follow this carefully...
o) Install the House of Moto to c:\HouseOfMoto
o) Install HouseOfMoto-xt926 into c:\HouseOfMoto
o) Inside the c:\HouseOfMoto directory, create an FXZ_9.8.79_xt926 folder
Here's the part where people get it wrong. When you open your VRZ_XT926_9.8.1Q-79-1_CFC.xml.zip file, you will see a directory inside it. You must go INTO the directory inside the zip. There you will see a whole bunch of files. Select them all, and extract them into the FXZ_9.8.79_xt926 folder you just created. All the files must be at the root of the FXZ_9.8.79_xt926 folder, NOT in a sub folder within it. If you have this:
c:\HouseOfMoto\FXZ_9.8.79_xt926\VRZ_XT926_9.8.1Q-79-1_CFC.xml\boot.img
It's wrong. If instead you have this:
c:\HouseOfMoto\FXZ_9.8.79_xt926\boot.img
It's correct.
When you run the HouseOfMoto.bat the first time it'll ask you for your phone. Enter xt926. Then when it asks for flash mode, select option 2 for FASTBOOT [SNAPDRAGON]. Then you're good to go.
