[ROM] Droid Concepts | 4.3 | XT926
30 replies to this topic
#1 EmericanX
EmericanX
    Developer
  • 1,027 posts
  • Twitter:@EmericanX
  • LocationPrince George, VA
Posted 14 September 2013 - 07:34 PM
A FULL SOURCE BASED BAG OF TRICKS!
Features:
  • Hardkey rebinding
  • Status bar Clock options
  • LockClock
  • DSP
  • File Manager
  • Focal
  • Apollo
  • Apex launcher
  • Torch
  • Trickster Mod
  • Advanced Options (sensor lights, screen temp, vibration control, sound boost)
  • Lock Screen shortcuts
  • Theme Manager
  • notification drawer styles
  • Quick Settings options
  • custom carrier label
  • expanded desktop
  • notification led control
  • battery light control
  • Music controls
  • camera widget on/off
  • rotation control
  • color and transparent status bar setting
  • etc etc
INSTALL:
  • Download ROM
  • Reboot into recovery
  • Full data/cache wipe
  • Flash DC zip *Gapps are built in
  • Reboot system and Enjoy!
CREDITS:
cphelps76 for his hard undeniable work in this project, Cyanogenmod for the base. Buckmarble for kernel source. Dhaker29 and Hashcode for their relentless Moto support!
SCREEN SHOTS:
will come when I've got time to upload.
DOWNLOAD:
DROID-CONCEPTS 4.3 | XT926 | VZW ->
  • neckchop, BionicMan69, jtommyj and 3 others like this
#2 localceleb
localceleb
  • 74 posts
Posted 14 September 2013 - 07:57 PM
Ohhhhh nice!
#3 trebills
trebills
  • 73 posts
Posted 14 September 2013 - 09:00 PM
I don't think the download link works, for me anyway.
sent from my RAZR Maxx HD
  • bigdanmeys13 likes this
#4 bigdanmeys13
bigdanmeys13
  • 31 posts
  • Current Device(s):Motorola Droid Razr Maxx HD
Posted 15 September 2013 - 12:12 AM
Download link appears to be broken. Can't access on phone or PC... Sounds awesome, though, can't wait to try!
#5 clydei
clydei
    Auto Parts Lifer
  • 58 posts
  • LocationSalem, Oregon
  • Current Device(s):Moto X Dev (GSM)
Posted 15 September 2013 - 04:49 AM
Here is a link that worked for me:
  • BionicMan69 likes this
#6 EmericanX
EmericanX
    Developer
  • 1,027 posts
Posted 15 September 2013 - 07:19 AM
Uploading update now. I'm gonna change the link in the OP to link to the directory for the device instead.
  • trikotret and bigdanmeys13 like this
#7 asilentcivilian
asilentcivilian
  • 28 posts
Posted 15 September 2013 - 11:51 AM
Superuser and lock screen settings are jacked up. Pretty boss otherwise so far!
Sent from my GT-N8013 using Tapatalk 4
  • cmh714 likes this
#8 cmh714
Posted 15 September 2013 - 12:57 PM
Yep agree with above cannot get superuser so kind of hard to work with. But definitely looks nice. Also had some FC's in Settings Interface in a few spots.
Also, I am struggling to authenticate to my wifi for some reason.....was going to run wifical.sh if it exists, but dont have root :)
#9 localceleb
localceleb
  • 74 posts
Posted 15 September 2013 - 01:44 PM
Root isn't included with the ROM, but can be flashed manually. Quite easy. Download zip below and flash in recovery. Reboot and you should have root.
Sent from my Razr HD using Tapatalk 2
#10 cmh714
Posted 15 September 2013 - 02:52 PM
Superuser is supposed to be a part of the rom and its in the Settings. Adding another one isnt the normal method even if it works.
#11 localceleb
localceleb
  • 74 posts
Posted 15 September 2013 - 03:46 PM
If you navigate to /system/app and scroll down to the S's you'll notice superuser.apk is nowhere to be found! Which means it was left out. The settings you see are built in to the ROM, but with out the apk and associated binaries you will not have root.
Post edited by johnthehillbilly, removed possible inflammatory remarks
#12 bjoostema1933
bjoostema1933
  • 122 posts
  • LocationNorth Carolina
  • Current Device(s):Razr HD Maxx /Nexus 7
Posted 15 September 2013 - 03:52 PM
I haven't ran a 4.3 yet that didn't have a couple reboots but this firmware is smooth.  I'm going to wait until the initial bugs get squashed but awesome work EmericanX!  I really like the potential this project has, keep up the awesome work man!
#13 johnthehillbilly
Posted 15 September 2013 - 04:01 PM
@localceleb ..... your post has been edited.... no need for name calling and or sideways remarks....
  • neckchop likes this
#14 localceleb
localceleb
  • 74 posts
Posted 15 September 2013 - 04:27 PM
Lolz
#15 Chahta
Chahta
  • 81 posts
  • Twitter:toph4er
  • Current Device(s):Droid X
Posted 16 September 2013 - 04:58 AM
Looking forward to flashing this, Simplex was beautiful on OG
#16 bigdanmeys13
bigdanmeys13
  • 31 posts
Posted 16 September 2013 - 05:09 AM
Other than settings FC's, this ROM is slicker than snot on a doorknob! Great work! Looking forward to updates.
  • bjoostema1933 likes this
#17 EmericanX
EmericanX
    Developer
  • 1,027 posts
Posted 17 September 2013 - 05:03 PM
I'll try to cover multiple noted issues Lol..
First. Davros and Csphelps did most of the work on this build. As I am part of Droid Concepts, I'm simply bringing in some Moto love!
I am aware of the settings.. "Device advance settings" FC. We're looking into a way to fix this without separating a branch for the Settings source.
Lastly. You won't find a superuser.apk due to the fact that super user is embedded into settings. You just simply do not need a separate apk these days. But, there is an issue with root on the moto builds. I've pulled logcats and started trying to narrow it down.
As another noted you can flash a root.zip in the mean time as a work around.
Sent from my Razr HD using Tapatalk 4
  • neckchop, llawen, cmh714 and 2 others like this
#18 llawen
llawen
    android tweaker
  • 551 posts
  • Twitter:@llawen
  • LocationGlenn hieghts, Texas
  • Current Device(s):razr maxx hd
Posted 21 September 2013 - 02:19 PM
Bluetooth does work. Tried several work a rounds for hot spot no go. I hope you can get it working. Awesome ROM. And again full 4g signal sitting in my chair in two story house. Awesome.
#19 localceleb
localceleb
  • 74 posts
Posted 04 October 2013 - 11:33 AM
Any planned updates? This was pretty solid for me.
#20 BionicMan69
BionicMan69
    Android Scientist
  • 142 posts
  • Twitter:@BionicMan_69
  • LocationCookeville, TN
  • Current Device(s):Motorola Droid Razr Maxx HD, Motorola Droid Bionic, Motorola Xoom, HTC Flyer
Posted 23 October 2013 - 04:02 PM
I'd have to say out of all the 4.3 roms for the XT926, this would be on the bottom of my list and the last 4.3 rom I would suggest using. Advance settings still force closes, some apps do too, takes forever to get a signal sometimes, takes forever to get on the play store the first time, when you do have a signal shows its solid and strong but it is real slow data speeds, at least MMS does work. I'm not bashing, I like the look of the ROM but it still needs a lot of work to be up to par with the other 4.3 ROMs.
Sent from my Razr HD using Xparent Skyblue Tapatalk 2
