4.3 rom no reboot help thread
Posted 15 September 2013 - 05:43 AM
Posted 15 September 2013 - 11:57 AM
Also go to my goodies when there. I have the newest twrp's posted.
Posted 15 September 2013 - 02:51 PM
I read that post also. Only problem is when I get stuck at the logo only thing I can get to is fastboot. There were a few times I can count on one hand where I was able to get back to recovery. My only option at that point is to use Matt's utility and flash a fresh system then turn the phone off then go to recovery. If I use the method on xda I have to FAC reset evey time I do the next step and when all installed it still gets stuck.
Posted 15 September 2013 - 03:24 PM
Do you hold all keys til black? Let go power? Wait for BL options? Vol.....
You do know the charging cord can also mess you up. I hate the charge mode function. I would like to remove it.
Posted 15 September 2013 - 04:15 PM
Posted 15 September 2013 - 06:30 PM
Posted 16 September 2013 - 03:31 AM
Hmm. If I had to guess, the lack of reboot might be due to a non-working superuser.Sent from my XT907 using Tapatalk 4
If su is the issue how would somebody go about figuring that out?
Here's a weird thing also. When I install a new system with Matt's utility. Nothing to do with Matt's tool but I get all booted and when the screen goes to sleep or I hit power to put it to sleep and then wake the phone the wallpaper changes to what the 4.3 ROM had. Does it every time I restotemy system like there's remnants of 4.3 causing issues right off.
Posted 16 September 2013 - 03:37 AM
That's Google backing up your settings and stuff...If su is the issue how would somebody go about figuring that out?
I believe some of the ROM devs haven't set up su correctly - it requires a su daemon now to work properly - if they ported straight from 4.2 su probably would be broken. I know SuperSu has a flashable version that works with 4.3 and I believe the new Superuser (koush version) has one as well
Posted 16 September 2013 - 03:55 AM
