Softbricked hardbricked pwned owned xt912.
Best Answer SYSo , 17 September 2013 - 05:41 PM
johnthehillbilly let me tell you, you are one of the most helpful people I have met on this forum. Second, I seem to have fixed the issue. For some reason if you move safestrap to your external sd card everything goes to hell. By this I mean you can't run any custom rom. It just says you have nothing installed and when you go to install it, it says you dont have enough space. Because you really do have your roms installed ss just cant find them. So yeah that seems to be the issue and as for matts utility i was running it at 4% battery and everything kept failing. Is that why? Haha
Go to the full post
3 replies to this topic
#1 SYSo
SYSo
    Well, I think I know what I'm doing.
  • 23 posts
  • Twitter:@manisrobby
  • Current Device(s):Droid Razr XT912
Posted 17 September 2013 - 05:20 PM
Yeah. so I think this is the end. I deleted my stock os with safestrap. Then I moved safestrap to my external sd card. Now the only things I can access are ss and ap fastboot. Matts utility isnt working. I can't wipe my internal storage for some reason in ss and even though the phone shows up on my computer as mot interface it wont let me get to any of the files. So if any badass is willing to take on this challenge of helping me. I love you.
      ___           ___           ___           ___
     /\  \         |\__\         /\  \         /\  \
  _\:\~\ \  \      |:|__|__   _\:\~\ \  \   /:/  \:\  \
 /\ \:\ \ \__\     /::::\__\ /\ \:\ \ \__\ /:/__/ \:\__\
 \:\ \:\ \/__/    /:/~~/~    \:\ \:\ \/__/ \:\  \ /:/  /
  \:\ \:\__\     /:/  /       \:\ \:\__\    \:\  /:/  /
   \:\/:/  /     \/__/         \:\/:/  /     \:\/:/  /
     \/__/                       \/__/         \/__/
#2 johnthehillbilly
Posted 17 September 2013 - 05:32 PM
If it is still booting into safestrap, then there is hope for it..... :)
So let's start from the beginning.... what prompted you to wipe stock (or was it just a simple mistake)....
When you try to run Matt's utility, do you get any errors, or is it "hanging" or just plain refusing to run?
You will need to keep it plugged into a wall charger to make sure your battery is not low...(your problems will be compounded if you attempt flashing with a low battery)
What OS are you using (on computer)
Do you have the latest Motorola drivers installed?(if running windows)
The ability to wipe internal should return once we have a successful flash back to stock...
Have you tried RSDlite instead of Matt's utility?
  • Memnoch73 and rickw like this
#3 SYSo
SYSo
  • 23 posts
Posted 17 September 2013 - 05:41 PM   Best Answer
  • rickw likes this
      ___           ___           ___           ___
     \/__/                       \/__/         \/__/
#4 johnthehillbilly
Posted 17 September 2013 - 05:52 PM
Yes .... running the utility at 4% battery..... no bueno LOL .... :) it will cause the failures.... and yes if you move safestrap folder off internal, you will lose all your ROMs until you put the folder back.... I personally would recommend getting fully charged .... run the utility (or RSDlite) to while everything and go back to stock Once back to stock... follow this thread ...
to get rid of any unwanted stuff on your storage(s).... then root .... reinstall safestrap.... have fun :) HD tappin' .... hillbilly style!!
