Excuse my crappy bionic for cheesecaking.
Mattlgroff's Notes:
- CDT.bin is upgraded, so there is no going back to GB from this.
- Android 4.04
Code:
ro.build.fingerprint == "RGSCA/XT910_MOTO_RGSCA/umts_spyder:4.0.4/6.7.2-180_SLC-31/1339768157:user/release-keys
Download:
MD5: 37BF5F8FE132DBFE7B76CF491A926B32
Thanks andlaw for the adapted install instructions from your DR thread:
Install instructions are using ES File Manager and Rom Manager (free) from the Play Store download these and be rooted on 651.167.3331 for Rogers. Yes rogers for Canada, not that other carrier stuff lol.
open rom manager free, hit OK, now press the home button.
open es file explorer, press YES, press menu, open settings, scroll down to Path settings and under Root settings: Enable
Up to Root (path settings)
Root Explorer (root settings)
Mount File System (root settings)
"DOWNLOAD THE ICS UPDATE ZIP AND PLACE INTO YOUR PHONES /CACHE DIRECTORY (not /system/cache, but in the root of the phone)"
open ES FILE EXPLORER, locate your /cache directory and then select the Blur_Version.651.167.3331.XT910.Rogers.en.CA.zip
(now choose Open With ROM MANAGER)
phone will restart, and begin installation of the ICS leak (takes 10-15minutes)
phone restarts, boot animation begins, Android is upgrading :: Profit success!! Celebrate!!!
Uploading to a mirror now... I have a public dropbox link for the moment PM me if you want it.
Screenshots(the wallpaper is stock with ICS, the apps were some installed from the tester):
