Stock 1% Battery?
Posted 29 June 2012 - 10:53 PM
Posted 29 June 2012 - 11:30 PM
Posted 30 June 2012 - 12:16 AM
I Like This 1% Battery Mod From The Artic
Question Can This Be Used On Stock .211 Or Is There An App Out ???
#4 Guest_BDH_*
Posted 30 June 2012 - 12:17 AM
Would someone be able to make one..? I'd love to have a stock one.
For what build? If you want one for 211. Look in the thread for Arctic ROM. I put one in the OP using the stock ICS icons.
Mine will work on stock 211.
Edited by spc_hicks09, 30 June 2012 - 12:17 AM.
Posted 30 June 2012 - 06:13 AM
Tried this on Stock 211 and lost the notification bar altogether. Not blank, but completely gone.
#6 Guest_BDH_*
Posted 30 June 2012 - 12:07 PM
Is your 211 deodexed? Did you wipe cache and dalvik before flashing?
Posted 30 June 2012 - 05:23 PM
No, yes, and yes.
#8 Guest_BDH_*
Posted 30 June 2012 - 05:26 PM
No, yes, and yes.
Need to be deodexed to use it.
#10 Guest_BDH_*
Posted 30 June 2012 - 05:40 PM
#12 Guest_BDH_*
Posted 30 June 2012 - 07:29 PM
Can't find it.
Sent from my Battle Droid
That was my fault, I meant the ROMs section. Here's a link:
[Stock-Rom]-De-Odexed-&-Zipaligned-6.16.211-Base
Posted 03 July 2012 - 05:44 PM
Well, look at the bright side... now you have more room on your screen
- dillanshives likes this
