My Razr Is Soft Bricked Please Please Help Me
Posted 01 July 2012 - 01:22 PM
#2 Guest_BDH_*
Posted 01 July 2012 - 01:27 PM
I was in tom toolbox and I accidentally flashed a boot logo that wasn't exactly compatible and now it boots into ap fasboot and says ap fasboot flash mode (s) (boot failure) invalid cg otv invalid sp data could someone help me with this I need my phone alot especially this time of day please help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Use the Unstuck Tool to flash the .211 boot.img
Posted 01 July 2012 - 02:14 PM
Posted 01 July 2012 - 02:24 PM
" sending 'boot' (8192 KB)... FAILED (remote: Battery Low) "
#5 Guest_BDH_*
Posted 01 July 2012 - 02:26 PM
My phone says battery low please connect data cable.
Power the phone down and charge then lol.
Posted 01 July 2012 - 02:32 PM
Posted 01 July 2012 - 02:35 PM
I took an old usb cable cut it in half keep the usb end and spliced the red and black wire. Then i took my back plate off than hooked the red wire to the positive battery post and black wire to the negative post. The post are maked at the bottom of the phone. And when u plug in the usb cord it now acts as a factory cable and gives the phone power. Then hook up your phones usb as regular and use rsd lite 5.6 to govback to stock or use the droid razr utility to go back to stock
lol thats wayyyyyy to much of a hassle I think hicks knows what he's talking about.
Posted 01 July 2012 - 02:36 PM
Exactly what you should do ^^^I took an old usb cable cut it in half keep the usb end and spliced the red and black wire. Then i took my back plate off than hooked the red wire to the positive battery post and black wire to the negative post. The post are maked at the bottom of the phone. And when u plug in the usb cord it now acts as a factory cable and gives the phone power. Then hook up your phones usb as regular and use rsd lite 5.6 to govback to stock or use the droid razr utility to go back to stock
Sent from my DROID RAZR using Xparent ICS Blue Tapatalk 2
#9 Guest_BDH_*
Posted 01 July 2012 - 02:46 PM
He only messed up the boot.img which means he still has a functional system.img he just needs to power off his phone then charge.
Edited by spc_hicks09, 01 July 2012 - 02:47 PM.
Posted 01 July 2012 - 03:07 PM
Posted 01 July 2012 - 03:20 PM
#12 Guest_BDH_*
Posted 01 July 2012 - 03:22 PM
How long should it take to charge?
Maybe an hour
Posted 01 July 2012 - 03:23 PM
Posted 01 July 2012 - 03:37 PM
Invalid CG OTV (CG: system): invalid SP data
Invalid cg version (CG: system)
i've tried the unstuck tool but it just says "waiting for device" and nothing happens. any other suggestions???
Posted 01 July 2012 - 04:04 PM
Posted 01 July 2012 - 04:07 PM
Posted 01 July 2012 - 04:13 PM
Posted 01 July 2012 - 04:34 PM
Invalid cg usually means you are trying to flash a fastboot file that isn't compatible with your phone. In other words, you probably have an XT910 and you're trying to fastboot a XT912 fastboot file.
I have the XT912. I honestly don't know how I screwed it up to start with (i think i was trying to uninstall safetrap and deleted something i shouldnt have) and i've been using the same utility i used to install the .211 upgrade. i also tried using the utility 1.6 to fastboot it back to .181 but no luck with that either. I tried the unstuck option on the 1.7 utility but it isnt recognizing my phone as being connected. im currently waiting for the battery to drain to try it that way but i had about 85% battery life before i messed it up so it may take awhile for it to drain before i can charge it again.
Posted 01 July 2012 - 05:16 PM
Do I have to reglue my phone?
Posted 01 July 2012 - 05:31 PM
