So I have a question. I ran out of partition space to backup my current ROM. So I tried to delete some previous backups I had made using tarp, however when I try and delete the particular backup tarp say it has completed but it is still there after reboot. Is there a particular place backups are found using file explorer? I can seem to find them anywhere I look. I've looked through SD card1. SD card0 and device. But the backups always show up when I reboot into recovery and I was able to delete a couple of backups using tarp but there are a few that just won't delete.. I'm stumped and need help.. Thank you in advance
deleteing rom backups with twrp
dolfns99
, Nov 08 2013 06:14 AM
3 replies to this topic
Posted 08 November 2013 - 06:14 AM
Posted 08 November 2013 - 06:22 AM
Go to twrp/backups internal or external wherever you save to. I think default is internal.
sig made by
Rinkle McBally
Posted 08 November 2013 - 06:25 AM
It has saved backups to both internal and external is what it is showing in twrp recovery, however when I use file manager, I have looked in all twrp folders/ backups and they are empty
Posted 08 November 2013 - 06:29 AM
I found them.. Just trying to learn where everything is..trial and error I guess .. Thank you!
- shane1 likes this
