Please Help! NO OS, Bootloader Unlocked
xt926 jb4.1.2 bootloader unlocked TWRP
21 replies to this topic
#1 Nickcco123
Nickcco123
  • 30 posts
Posted 08 November 2013 - 11:31 PM
Having a hell of a time trying to use RSD the newest version keep getting preflash fail tz. what happend was that I tried ota from .79 to 84 or something but bootloader is unlocked. so i am using TWRP recovery, wiped everything and now says no OS and says no root. will come to the bootloader unlocked warning and will not do anything from there?? what do i need to do i have tried downloading a 4.1.2 and also 4.1.1 firmware, and also edited the xml files to delete the getvar lines? what can I do i really need to get phone working
Thank You
Nick O
#2 livinginkaos
Posted 09 November 2013 - 02:18 AM
It was 94. If it installed even part way, you will likely need to use its firmware. The tz fail means you are trying to flash an older security version. Here is the DL link for it.
Also, please refrain from doing multiple threads/posts on the same issue. Sent from my G2
  • johnthehillbilly and shane1 like this
#3 Nickcco123
Nickcco123
  • 30 posts
Posted 09 November 2013 - 08:47 AM
Thank you will try out and let you know if that works sorry for posting in multiple threads
#4 Nickcco123
Nickcco123
  • 30 posts
Posted 09 November 2013 - 10:12 AM
that worked phone is back up thank you. Am I able to root this version now
#5 livinginkaos
Posted 09 November 2013 - 10:18 AM
Not at this time that I am aware of. Be sure NOT to attempt the motochopper v1.3 as this will mess things up.
Sent From My DEV X
#6 Nickcco123
Nickcco123
  • 30 posts
Posted 09 November 2013 - 10:55 AM
ok i appreciate it again thanks,you area life saver!
#7 livinginkaos
Posted 09 November 2013 - 11:00 AM
NP !
Sent From My DEV X
#8 SamuriHL
  • 43,456 posts
Posted 09 November 2013 - 11:37 AM
Wait, if bootloader is unlocked and you can flash twrp, you just flash SuperSU zip in twrp and root is done.  Or am I misreading this?
  • livinginkaos and RikRong like this
#9 livinginkaos
Posted 09 November 2013 - 01:43 PM
Woops. Missed the unlocked part. Been messing with so many of these issues ...... What Sam said!!
Sent From My DEV X
  • SamuriHL likes this
#10 Nickcco123
Nickcco123
  • 30 posts
Posted 09 November 2013 - 07:14 PM
awesome so just download SU.zip to sd card and then install through TWRP
#11 Nickcco123
Nickcco123
  • 30 posts
Posted 09 November 2013 - 07:18 PM
which utility to use to flash twrp again since you said dont use motochopper1.3 because will mess up
#12 SamuriHL
  • 43,456 posts
Posted 09 November 2013 - 07:26 PM
Fastboot can flash it.  fastboot flash recovery twrpfilenamegoeshere
#13 Nickcco123
Nickcco123
  • 30 posts
Posted 09 November 2013 - 08:56 PM
Can I use droid utility razr hd 1.2.1 and flash twrp using that
#14 cmh714
Posted 10 November 2013 - 07:15 AM
yes, it will flash the 2.5.0 version of TWRP, or replace the twrp image that Matt provides with 2.6.1 or 2.6.3 so that will be flashed instead.
#15 SamuriHL
  • 43,456 posts
Posted 10 November 2013 - 07:32 AM
Or grab my universal root method and drop your twrp image into it.  It'll flash twrp for you then walk you through sideloading supersu.  :)
  • cmh714 likes this
#16 Nickcco123
Nickcco123
  • 30 posts
Posted 10 November 2013 - 10:26 PM
Awesome thank you everyone for the help!
#17 Nickcco123
Nickcco123
  • 30 posts
Posted 13 November 2013 - 11:15 PM
hey guys im still having issues understanding how to flash custom recovery. sorry for not understanding how to do this but if you could maybe explain how to flash custom recovery (twrp) again. please and thank you sorry again!
#18 SamuriHL
  • 43,456 posts
Posted 14 November 2013 - 04:29 AM
[Utility]Flash-CWM-or-TWRP-Recovery-1-Click-{UPDATED-7-11-13}-V6!
Sent from my Xoom using Tapatalk 4
  • Nickcco123 likes this
#19 Nickcco123
Nickcco123
  • 30 posts
Posted 14 November 2013 - 04:35 PM
Thanks man!
#20 Nickcco123
Nickcco123
  • 30 posts
Posted 16 November 2013 - 09:59 PM
Hey tried this said fail because no SuperUser and is not rooted so it rebooted my phone. Then i booted into recovery and is still stock android recovery
Also tagged with one or more of these keywords: xt926, jb4.1.2, bootloader unlocked, TWRP
