6.16.214 Downgrade Leak (To 6.16.211)
Posted 04 July 2012 - 11:33 PM
Download:
This undoes what the 6.16.214 leak zip did to 6.16.211. Must be on stock and unmodified 6.16.214. This is for flashing in Motorola Recovery.
Not sure why anyone would want this but I pulled it anyway....
Welcome to leak season folks!
- just lou and tbhall77 like this
Posted 05 July 2012 - 01:10 AM
Posted 05 July 2012 - 07:16 AM
X
- Geezio and wabmorgan like this
Posted 05 July 2012 - 07:50 AM
So this takes you back to what 211 was but it's gonna say 215? So basically a downgrade with a higher leak number?
I'm confused. lol
Posted 05 July 2012 - 08:18 AM
Downgrade packages are always listed this way.
- just lou likes this
Posted 05 July 2012 - 08:28 AM
Posted 05 July 2012 - 08:32 AM
Posted 05 July 2012 - 08:40 AM
Posted 05 July 2012 - 08:55 AM
No it does not imply a problem. You and others should not take implications from this, we have found them for previous versions in the past they were officially released.Does this imply that there is a problem with 214? I wonder if the plungers have had any problems with 214.
215 is just the description label so it can be found from 214 test devices, when you install this over 214 the build.prop will say 211 again.
Posted 05 July 2012 - 09:01 AM
Posted 05 July 2012 - 09:14 AM
And download it from recovery..or do I need to be on.214?
Posted 05 July 2012 - 09:16 AM
This is for if you upgraded to .214 and want to downgrade back to .211. If you are on .211 already then there is no reason for you to use it. It just takes you back to .211I'm on .211 rooted....can I put this on my sd-ext card
Posted 05 July 2012 - 09:23 AM
Ok thanks....
Posted 05 July 2012 - 11:18 AM
Posted 05 July 2012 - 12:40 PM
Posted 05 July 2012 - 03:14 PM
There is nothing wrong with 214 so far but if for whatever crazy reason you want to downgrade (maybe a rom is more compatible with 211) this is probably the easiest way to do it
Posted 05 July 2012 - 05:28 PM
Option 2 with 6.16.211 zip on your SD card. Then install the zip from RecoveryMatt, if a person wanted to downgrade, couldn't they just go back to Utility 1.7 and use option 1??
Posted 05 July 2012 - 06:46 PM
Don't get me wrong for a moment, I'm not going back! I was just sayin'...
LUV UR WORK MATT! Do you have a donation thread/site (to help support your efforts and beer fund)?
Posted 05 July 2012 - 07:55 PM
There is a link in my signature, thanksDon't get me wrong for a moment, I'm not going back! I was just sayin'...
