idk it gives me an internet error nut internet is fine
Cant reboot phone after installing fonts
#21
Posted 27 November 2013 - 09:25 AM
#22
Posted 27 November 2013 - 10:01 AM
RSDLite sees the device and im about to start flashing. wish me luck
#23
Posted 27 November 2013 - 10:02 AM
getting error "unknown fast boot command"
#24
Posted 27 November 2013 - 10:24 AM
any help on how to fix this error?
#25
Posted 27 November 2013 - 10:35 AM
#26
Posted 27 November 2013 - 10:40 AM
#27
Posted 27 November 2013 - 10:43 AM
Can you be more specific on the command it's trying to flash?
- johnthehillbilly likes this
#28
Posted 27 November 2013 - 10:51 AM
its RSDLite 6.1.4 its on my flash drive and it starts to flash but before it does anything it stops and says"Failed Flashing Process. Uknown Fastboot Command..."
#29
Posted 27 November 2013 - 11:21 AM
Post the SWDL.txt file in your RSD directory.
#30
Posted 27 November 2013 - 11:35 AM
here
#31
Posted 27 November 2013 - 11:44 AM
#32
Posted 27 November 2013 - 11:46 AM
will try it and post results
#33
Posted 27 November 2013 - 11:51 AM
actually can you do that for me so idont mess anything up? heres the XML file that was in it
#34
Posted 27 November 2013 - 12:01 PM
#35
Posted 27 November 2013 - 12:02 PM
alright thank you
#37
Posted 27 November 2013 - 12:13 PM
If only there were a java tool you could drop into the FXZ directory, run it, select the xml file, and hit a generate button to output a fixed RSD xml script................
- johnthehillbilly and shane1 like this
#38
Posted 27 November 2013 - 12:14 PM
If only indeed...........oh wait .....um yeah........ LOLIf only there were a java tool you could drop into the FXZ directory, run it, select the xml file, and hit a generate button to output a fixed RSD xml script................
#39
Posted 27 November 2013 - 12:16 PM
it started and i going god so far. and just ot be clear only the /data folder will be wiped correct? the internal sdcard will not be touched?
