Droid Razr Flashing Problems.
Posted 02 January 2012 - 05:34 PM
Posted 02 January 2012 - 05:38 PM
- mattlgroff likes this
Posted 02 January 2012 - 05:44 PM
I think I tried that already, i'm not for sure though I'll try again.Well to start. You can't have Razr Bootstrap and Safestrap at the sametime. try disabling superuser permission for Razr Bootstrap or uninstall the app reboot. Then use safestrap if that is what you r trying to do.
Posted 02 January 2012 - 05:50 PM
Nope I just uninstalled it and tried it keeps saying it:I think I tried that already, i'm not for sure though I'll try again.
Finding update package...
Opening update package...
Installing update...
Installation aborted.
Posted 02 January 2012 - 06:49 PM
Donate $10 or more to our Phones For Devs Giveaway and get a Custom Forum title and help the Make a wish Foundation details here:
http://www.droidrzr....-custom-titles/#6
Posted 03 January 2012 - 04:16 AM
(ss=safestrap)
This is what I would do
1. Enable safe-mode
2. Wipe data/factory reset
3. wipe cache partition
4. under mounts/storage "wipe system"
5. Advanced "Wipe dalvik"
6. Disable safe-mode and reboot
7. in your app drawer open SS
8. Uninstall recovery
9. in apps manager remove SS
10. UN-root
11. Do a quick SYNC
12. pwr off your Razr
13. hold vol/pwr until MOTO recovery loads
14 "recovery"
15 wipe data/factory reset
16. Zergrush Root
17 . Install SS and only use SS
Posted 03 January 2012 - 04:35 AM
sliced by my Razr on Tapatalk
- rickyheferle likes this
Posted 03 January 2012 - 06:14 PM
Tried that all didn't workSomeone help me or correct me,l but this does sound like the improper removal of bootstrap and then running SS? I thought I had read this before. I have never used bootstrap on my razr. it was never SAFE enough at the time. Im just too much in love with SS.
(ss=safestrap)
1. Enable safe-mode
10. UN-root
11. Do a quick SYNC
14 "recovery"
16. Zergrush Root
Yup, that's what i would do. I'd say there's a good chance some decent damage has been done from multiple recoveries. I'd say a complete wipe & start over with safe strap (only) is your best bet. Let us know what you do, and how it works.
And I just did this now it didn't work :/
Posted 03 January 2012 - 07:05 PM
[Fastboot-Files]-Gingerbread-2.3.5-Cdma-Droid-Razr-Xt912-Verizon-Usa-[Fastboot-Files]#entry2738
Complete restart
Also tagged with one or more of these keywords: Droid Razr, flashing, flash, problem
