Changing Boot Logo Using Flashable Zip
7 replies to this topic
#1 shawnlee6184
shawnlee6184
  • 118 posts
Posted 20 July 2012 - 11:51 AM
I downloaded a boot logo wondering if i install it will i brick using cwm and can i use safestrap
#2 Aliceics
Aliceics
    Graphic Designer | Themer
  • 550 posts
  • Twitter:alicerzr
  • Google+:littlemissalice1@gmail.com
Posted 20 July 2012 - 12:07 PM
There is a program for changing logos in fast boot mode. Its in the Mods section.
#3 Alex.Abraham
Alex.Abraham
  • 477 posts
  • Twitter:aabraham123456
  • LocationNew Jersey
Posted 20 July 2012 - 12:31 PM
I was asking around for the very same thing to add it as an option for my utility. Unfortunately, after researching the idea and asking devs/admins on the forum, I concluded that it is not possible and we have to stick to flashing logos with a computer and putting the phone in AP Fastboot mode
#4 shawnlee6184
shawnlee6184
  • 118 posts
Posted 20 July 2012 - 12:39 PM
Didnt want to use utility thought maybe root browser
#5 pacman377
pacman377
  • 12 posts
Posted 20 July 2012 - 05:08 PM
Root browser wont work either, it only works through fastboot. Its not that bad. Typing the code transferring and rebooting only takes about 30 seconds max.
#6 PillClinton
PillClinton
    #FireGaryBettman
  • 441 posts
  • Twitter:530SharksFan
  • LocationNorCal
Posted 20 July 2012 - 05:18 PM
It takes even less time if you use
's utility! Super easy to use, plus an easy way to add in your own logos as well if you don't like any of the included ones.
#7 Nitewolf
Nitewolf
    Member of the BEST android community
  • 643 posts
Posted 29 July 2012 - 05:51 PM
+1
#8 tucstwo
  • Google+:tucstwo@gmail.com
Posted 29 July 2012 - 06:00 PM
Boot logo right? Not a boot animation? Boot animations can be installed just by placing them in system/media just Label it bootanimation.zip and rename your stock one to bootanimation.zip.bak so you have a back up.
Boot logos are flashed in fastboot mode with ADB...er fastboot really.
On your computer, if you're familiar with ADB, fastboot and command line stuff it's
Fastboot flash logo.bin LocationAndNameOfLogo.bin or img (on your computer)
Itll send it and write it and you're in business. Boot logos are in their own partition, animations are within the android file system.
