Razr HD MAXX Powers on in Fastboot PLEASE HELP ><
30 replies to this topic
#21 cmh714
Posted 18 January 2014 - 07:52 PM
unplug and hit power reboot and see if it that fixed it
#22 SamuriHL
  • 43,370 posts
Posted 18 January 2014 - 07:57 PM
I so need to finish my FXZ Flasher program for things like this.
  • cmh714 likes this
#23 Sluicebox
Sluicebox
  • 16 posts
YOU ARE A LIFESAVER!!!!! Thank you so much for all the help, sorry i was kinda anxious about it....i already started looking into buying a new phone lol...you saved me a few hundred bucks! so where do i donate to this site? =)
I'll probably be back soon to see if i can actually get the root to work, reason i was trying was to get the mobile hotspot working on my phone....would a root even do that?
#24 SamuriHL
  • 43,370 posts
Posted 18 January 2014 - 07:59 PM
Yes. You can do the entitlement hack. Search for it once you get root sorted out.
#25 cmh714
Posted 18 January 2014 - 08:07 PM
I personally dont take donations, but the site could always use a little something to keep the lights on :)
#26 Sluicebox
Sluicebox
  • 16 posts
Posted 18 January 2014 - 08:10 PM
Just donated, thanks again! I'll definitely be back once i muster up the courage to root my phone lmao
  • livinginkaos and cmh714 like this
#27 cmh714
Posted 18 January 2014 - 08:15 PM
Plenty of good info in our forums, just read up and you should be ok. Cheers.
  • SamuriHL likes this
#28 phonemodder74
phonemodder74
  • LocationIndiana
  • Current Device(s):HTC Thunderbolt, Droid Razr xt912, Galaxy s3 t999 Tmoble and I535 Verizon, Galaxy s2 t989 t moble, Droid Razr HD xt926 all rooted!
Posted 16 February 2014 - 11:50 AM
Stuck in Fastboot at power off!
This could help you fix it!
Droid Razr HD 9.18.94.xt926.verizon.en.US
First I would advise you to read everything before doing anything because this will erase everything on your phone!
SO beware and make back up of everything first
Just for info I was rooted and I didn't loose root by doing this I just re installed the Supersu app that was on the phone after I rooted!
I used Hide my root app to do this! I also used Root Checker to check root! I had no root until I re installed Supersu!
Rooted My Razr HD with SafeRoot for Galaxy S4
If you are in fastboot  you can turn screen off  hold down the volume up, volume down, and power at the same and select boot normal to get back in to your phone to make back up if you need to!
I used Minimal ADB and Fastboot program you can find
Make sure the phone is in debug mode then you can use the ADB to reboot phone!
1: Download Minimail ADB and Fastboot to your computer!
2: Install program to computer
3: Run program (C:\Program Files (x86)\Minimal ADB and Fastboot> will be displayed in a C:\ Box on windows!
4: Check to see if Droid Razr HD is linked to ADB by typing  ( adb devices ) tap <enter>
  Device will be desplayed by Serial Number
5: If your phone serial is displayed continue! by typing ( adb reboot!) Tap <enter>
This should reboot Your phone to the Fastboot screen razr goes to on powerdown when you are having this problem!
if you are already on the fastboot screen start up Minimal ADB and Fastboot!
then start here
6: Type in ( Fastboot devices ) Tap <enter> Again fastboot should display the Serial number of you Phone as did in ADB
7: Type in fastboot and commands with be displayed
8: Type in the command (fastboot -w)  this will Erase Userdata and cache< and format if supported by partition type>
Caution Step #8 Will set you phone completely back to factory start up!
9: Type (fastboot oem fb_mode_clear) it will tell you if successful!
10: Type (fastboot countinue) Phone will then reboot to normal operation!
Just as a test I shut the phone off and pluged in the charger to see if it worked?
Moto logo should show  for a coulple of secs and then go to battery charging!
You can then power up you phone as normal with power button!
simcard lock screen will be displayed
to unlock rotate phone clock wise 1/4 turn then slowly tap each corner starting with the lower left of the screen keep going clockwise till it shows a different screen!
You should be done and back to you operational phone!
Happy rooting!
#29 silentice05
silentice05
Posted 16 March 2014 - 10:40 AM
AP Fastboot Flash Mode (s)
10.9B(*) (sha-1e9f557, 2013-09-26 12:31:42)
eMMC Info: size 16GB
Device is LOCKED, Staus Code: 0
Battery OK
Transfer Mode:
USB Connected
Fastboot Reason:  Flash Failure
Please Help my son was fooling around  with his phone  that i just replaced and now it says this are there any steps inwhich will remedy this?? :unsure: Droid Razr HD xt926
#30 livinginkaos
Posted 16 March 2014 - 10:56 AM
Depending on what he did, you have a couple options. Try to boy into bptools. If it boots fine, all you need to do is flash a boot logo. Otherwise look up the house of Moto and flash the fxz.
Sent From My DEV X
  • RikRong likes this
#31 silentice05
silentice05
Posted 16 March 2014 - 12:03 PM
THe phone does not turn on or off it stays at the ap fastboot screen.. Even if i hold down the power and vol. dwn or up.
