Damn APK's !
57 replies to this topic
#1 jimt68
jimt68
  • 73 posts
Posted 26 January 2014 - 08:05 PM
I screwed up my root droid razr m. I thought it was no problem to delete apk's so I moved all my system apk's to Box.com. I'm not bricked but my phone can't get passed the boot screen. My computer can't even access my phone files. I can't even get into recovery. Any suggestions? I have everything backed up in several areas but can't access anything.
Sent from my ASUS Transformer Pad TF300T using Tapatalk
#2 johnthehillbilly
Posted 26 January 2014 - 08:22 PM
If you moved all system apk's off the phone then you basically have no system for it to boot...... You will need to flash system via fastboot or use the house of moto found here
to FXZ to get your system back
"No more training do you require...... already know you, that which you need...."
  • jl90 and jimt68 like this
#3 jimt68
jimt68
  • 73 posts
Posted 26 January 2014 - 08:51 PM
Thanks! I will give it a shot as soon as I get the right cable. I just bought a data sync cable off Ebay. The cables I have won't let me install the driver for some reason.
#4 johnthehillbilly
Posted 26 January 2014 - 08:53 PM
All you really need is the OEM cable that came with your phone :):)
  • jl90 likes this
#5 jimt68
jimt68
  • 73 posts
Posted 28 January 2014 - 10:41 AM
I am not completely convinced that I am doing something wrong. There are 4 FXZ files that pertain to my xt907. I have tried them all. On 3 of them, I get an error message "CRC failed in....File is broken". The fourth one extracted fine, but when I run the .bat file and enter my phone, I receive "File not found". So I figured I would try to re-download the FXZ. But now I can't access the sbf.droid-developers page anymore. Is there another way to install the FXZ files? Perhaps it's been the developer's page that isn't working for me and has corrupted xt907 files? Finally, could it be a problem with Firefox?
#6 livinginkaos
Posted 28 January 2014 - 03:20 PM
It is entirely possible.  I have let them know that the SBF site is down.  I also have been trying to  upload the 94 update to the DRDevs site but am having login issues.  If that gets fixed, I will get it uploaded for you.
#7 jimt68
jimt68
  • 73 posts
Posted 28 January 2014 - 05:45 PM
Ok thanks
#8 livinginkaos
Posted 28 January 2014 - 06:29 PM
Here it is -
Sent From My DEV X
#9 jimt68
jimt68
  • 73 posts
Posted 28 January 2014 - 07:30 PM
Thanks for trying. But it still says CFC file is broken. It's just that 1 error I can't seem to get past.
#10 jimt68
jimt68
  • 73 posts
Posted 28 January 2014 - 07:33 PM
But I did try to execute the .bat anyway. My phone got the sound back but still stuck on boot screen.
#11 jimt68
jimt68
  • 73 posts
Posted 28 January 2014 - 07:59 PM
CRC
#12 jimt68
jimt68
  • 73 posts
Posted 28 January 2014 - 09:41 PM
It's the system.img that is broken. Anymore ideas?
#13 jimt68
jimt68
  • 73 posts
Posted 29 January 2014 - 04:28 AM
Anyone?
#14 SamuriHL
  • 43,460 posts
Posted 29 January 2014 - 04:31 AM
  • jimt68 likes this
#15 iamhugger
iamhugger
  • 296 posts
  • Locationsouth dakota
  • Current Device(s):droid razr
Posted 29 January 2014 - 04:32 AM
Anyone?
I googled this and there are some interesting results, if you have not did a Google search you might want to try, but I am sure you have already, but if not, give it a try maybe it might make sense. Otherwise, just nevermind me because I am too eager. Weeeeeeeeeeeee
XT912 RaZR SpYdEr CDMA
hit ThAnKs if I was helpful!!!
#16 jimt68
jimt68
  • 73 posts
Posted 29 January 2014 - 04:44 AM
Thanks guys. I will give both a try. I did Google search last night, and basically older solutions that weren't really applicable.
#17 livinginkaos
Posted 29 January 2014 - 05:05 AM
My upload was bad. Sorry about that. Grab the one from sbf and you should be golden. I will fix mine later today.
Sent From My DEV X
  • jimt68 likes this
#18 jimt68
jimt68
  • 73 posts
Posted 29 January 2014 - 05:36 AM
Well the sbf worked. But now I have a low battery. I asked someone about a data cable previously, because I knew I needed something. However, I inquired about the wrong thing. I guess I need a different kind of cable.
#19 SamuriHL
  • 43,460 posts
Posted 29 January 2014 - 06:00 AM
#20 jimt68
jimt68
  • 73 posts
Posted 29 January 2014 - 06:10 AM
I hate to be a bother, but do I need the factory adapter, the programming cable, or both?
