APB FASTBOOT stuck. deleted rom
49 replies to this topic
#1 Zokajon
Zokajon
  • 16 posts
Posted 27 January 2014 - 02:53 PM
Hello guys. I am rookie here. was trying to put custom rom on my droid razr m, but bricked it and deleted stock rom. it is bootloader locked. it is on last ota update. how can i get it back to stock? i tried droid razr utility.. it is not working .. tried rsd lite.. it is giving me error.. please help me out. i tried and pretty much looked everywhere.. couldnt find answer.
#2 shane1
shane1
    Droid Elite
  • 1,596 posts
  • Twitter:1shane15
  • Locationny
Posted 27 January 2014 - 03:19 PM
Are you trying the correct sbf with rsd? What's the error?
sig made by
Rinkle McBally
#3 Zokajon
Zokajon
  • 16 posts
Posted 27 January 2014 - 03:38 PM
Hello. i deleted all the drivers and reinstalled motorola device manager and now rsd lite is not even finding my cellphone... it is showing qms fastboot
what should it show on device manager as?
#4 Zokajon
Zokajon
  • 16 posts
Posted 27 January 2014 - 04:15 PM
yeah it is not showing on RSD lite. sorry i forgot what it was writing on rsd lite. i am in army and i did not mess with this cellphone this week. alot of work...
#5 SamuriHL
  • 43,453 posts
Posted 27 January 2014 - 05:04 PM
There's simply not enough information here to help you.  You said you reinstalled the driver.  Does the phone get detected?  If you run fastboot.exe devices when the phone is plugged into USB and in AP Fastboot mode, does it find it?  Are you plugged into a USB2 rather than a USB3 port? (USB3 won't work).  Are you using the original USB cable that came with the phone?  Yes, it matters.  Just too many unknowns for anyone to tell you what the problem is.
#6 Zokajon
Zokajon
  • 16 posts
Posted 28 January 2014 - 03:41 AM
thats what it shows on my device manager as. but it is not showing up on rsd lite. it is USB 2. Windows 8. when i try to open fastboot.exe it automatically closes. it is original cable
  • Attached File  1.jpg   49.93KB   17 downloads
#7 SamuriHL
  • 43,453 posts
Posted 28 January 2014 - 04:04 AM
You don't open fastboot you run it from a cmd prompt. What is on the phone's screen when it's connected to USB? I want to know exactly what it says.
#8 Zokajon
Zokajon
  • 16 posts
Posted 28 January 2014 - 02:44 PM
it says Failed to hab check for boot: 0x56
Fast boot reason : boot failure
and it goes to AP fastboot automatically
#9 SamuriHL
  • 43,453 posts
Posted 28 January 2014 - 02:46 PM
So then you need to open a cmd prompt, and run: fastboot devices
That will show you what it sees.
#10 Zokajon
Zokajon
  • 16 posts
Posted 28 January 2014 - 02:53 PM
this is what it is showing now
  • Attached File  2.png   11.13KB   26 downloads
#11 SamuriHL
  • 43,453 posts
Posted 28 January 2014 - 02:57 PM
Alright, well, this is a start.  Now, what is the filename of the FXZ you're trying to flash?  We're going to skip RSD and try something else.  But I need to make sure you're flashing the right thing first.
#12 Zokajon
Zokajon
  • 16 posts
Posted 28 January 2014 - 03:12 PM
VRZ_XT907_9.8.1Q-94-1_CFC.xml
 this is the name of the file
#13 SamuriHL
  • 43,453 posts
Posted 28 January 2014 - 03:34 PM
Follow my directions EXACTLY.  I suggesting reading these multiple times before doing it.
Download:
and
o) Extract your FXZ
o) In the same folder that contains boot.img, extract the SNAPDRAGON_FXZ_SUPPORT.zip file.  It will add 3 folders to your extracted FXZ directory: Windows, Darwin, and Linux
o) Copy the FXZ-Flasher.jar to the same directory (the one that contains boot.img)
o) Run the FXZ-Flasher.jar.  It's an executable java jar so it should just run if you have java installed.
o) Press the ... button and select the VRZ_XT907_9.8.1Q-94-1_CFC.xml file
o) Press the Flash KEEP DATA button
o) With your phone connected to USB and in AP Fastboot mode, press the Flash button on the screen that comes up
o) Wait until the window title says "Flash Complete"
o) Highlight the contents of the window with the mouse, then press control-c
o) Paste the results into this thread.
#14 Zokajon
Zokajon
  • 16 posts
Posted 28 January 2014 - 03:41 PM
C:\Users\Jon\Desktop\VRZ_XT907_9.8.1Q-94-1_CFC.xml\Windows\fastboot.exe flash partition gpt_main0.bin
C:\Users\Jon\Desktop\VRZ_XT907_9.8.1Q-94-1_CFC.xml\Windows\fastboot.exe flash sbl1 sbl1.mbn
C:\Users\Jon\Desktop\VRZ_XT907_9.8.1Q-94-1_CFC.xml\Windows\fastboot.exe flash sbl2 sbl2.mbn
C:\Users\Jon\Desktop\VRZ_XT907_9.8.1Q-94-1_CFC.xml\Windows\fastboot.exe flash sbl3 sbl3.mbn
C:\Users\Jon\Desktop\VRZ_XT907_9.8.1Q-94-1_CFC.xml\Windows\fastboot.exe flash rpm rpm.mbn
C:\Users\Jon\Desktop\VRZ_XT907_9.8.1Q-94-1_CFC.xml\Windows\fastboot.exe flash tz tz.mbn
C:\Users\Jon\Desktop\VRZ_XT907_9.8.1Q-94-1_CFC.xml\Windows\fastboot.exe flash aboot emmc_appsboot.mbn
C:\Users\Jon\Desktop\VRZ_XT907_9.8.1Q-94-1_CFC.xml\Windows\fastboot.exe flash modem NON-HLOS.bin
C:\Users\Jon\Desktop\VRZ_XT907_9.8.1Q-94-1_CFC.xml\Windows\fastboot.exe flash fsg fsg.mbn
C:\Users\Jon\Desktop\VRZ_XT907_9.8.1Q-94-1_CFC.xml\Windows\fastboot.exe erase modemst1
C:\Users\Jon\Desktop\VRZ_XT907_9.8.1Q-94-1_CFC.xml\Windows\fastboot.exe erase modemst2
C:\Users\Jon\Desktop\VRZ_XT907_9.8.1Q-94-1_CFC.xml\Windows\fastboot.exe flash logo logo.bin
C:\Users\Jon\Desktop\VRZ_XT907_9.8.1Q-94-1_CFC.xml\Windows\fastboot.exe flash devtree device_tree.bin
C:\Users\Jon\Desktop\VRZ_XT907_9.8.1Q-94-1_CFC.xml\Windows\fastboot.exe flash boot boot.img
C:\Users\Jon\Desktop\VRZ_XT907_9.8.1Q-94-1_CFC.xml\Windows\fastboot.exe flash recovery recovery.img
C:\Users\Jon\Desktop\VRZ_XT907_9.8.1Q-94-1_CFC.xml\Windows\fastboot.exe flash cdrom cdrom
C:\Users\Jon\Desktop\VRZ_XT907_9.8.1Q-94-1_CFC.xml\Windows\fastboot.exe flash system system.img
C:\Users\Jon\Desktop\VRZ_XT907_9.8.1Q-94-1_CFC.xml\Windows\fastboot.exe erase tombstones
C:\Users\Jon\Desktop\VRZ_XT907_9.8.1Q-94-1_CFC.xml\Windows\fastboot.exe erase cache
C:\Users\Jon\Desktop\VRZ_XT907_9.8.1Q-94-1_CFC.xml\Windows\fastboot.exe reboot
#15 SamuriHL
  • 43,453 posts
Posted 28 January 2014 - 03:44 PM
What the?  That's all it showed?  Hmmm, something isn't right.  Damnit.  Doesn't look like it executed the commands.  :(
#16 SamuriHL
  • 43,453 posts
Posted 28 January 2014 - 03:48 PM
Copy all those commands and create a new runme.bat file.  Paste it all into the bat file.  Save it then run it.  I don't know why it's not executing on your machine.
#17 Zokajon
Zokajon
  • 16 posts
Posted 28 January 2014 - 03:49 PM
that is all it had bro :(. i reflashed it and it is same thing
#18 SamuriHL
  • 43,453 posts
Posted 28 January 2014 - 03:50 PM
Then stick it in a bat file and run it that way.
#19 Zokajon
Zokajon
  • 16 posts
Posted 28 January 2014 - 03:59 PM
what bat file?
#20 SamuriHL
  • 43,453 posts
Posted 28 January 2014 - 04:06 PM
