Horrible Battery Life.
Posted 05 January 2012 - 05:07 PM
My first, out of the box charge lasted 4hrs. My usage was a few calls and texts.
Second was this morning, did a ton of set up with adw, handcent etc. Phone Died in 3hrs.
Flashed to razxr a bit ago. Re did all my settings, phone is dead four hours later.
I have been using Android since the g1 came to America, never seen such horrendous battery life. Any advice?
Posted 05 January 2012 - 05:19 PM
Other than that try to wipe battery stats.
I usually charge to 100%, wipe battery stats, fully discharge to 0%, recharge back to 100%.
Posted 05 January 2012 - 05:28 PM
sliced by my Razr on Tapatalk
Posted 05 January 2012 - 05:29 PM
To get that short of batter life, I would assume you are in a very weak 4G coverage area or something. If that is the case, and you are not using Smart Actions or Juice Defender to control the radios, your phone will be constantly trying to get a stable 4G signal which would devastate the battery. 4G in and of itself is very demanding on a battery even in strong signal areas. If your area has weak or no 4G signal, you should probably disable the 4G radio (found in Wireless settings). Setting a Smart Action or using Juice Defender to disable the wireless radios when your screen is turned off can hugely save battery between active uses. After your radios, the next likely culprits are apps trying to sync too often (prevents phone from going into low-power/low speed mode) and screen brightness. Setting the brightness to either auto or a lower value can increase battery life noticeably.
There is actually a thread with many tips on how to squeeze more life out of this phone as well.
Posted 05 January 2012 - 05:46 PM
Posted 05 January 2012 - 06:34 PM
Posted 05 January 2012 - 06:47 PM
Posted 05 January 2012 - 08:47 PM
I did just think about it, I have been using google music all day to strean, could this one app cause my battery this much pain though?
When I workout I stream google music, and it definitely eats through my battery.
Posted 06 January 2012 - 09:13 AM
Get JuiceDefender Ultimate, it's a good investment.
Hey just a heads-up that's not good for the battery. Li-on batteries don't have 'memory' like the old Ni-cads did. So there's no need to charge it too 100% and let it die, actually the opposite.
Letting a Li-on battery die shortens it's lifespan every time it happens.
Also, if you have a case on your phone, you might want to take it off for prolonged charging, especially if it creates a lot of heat.
Last thing, you'd be suprised how much of a difference cleaning the contacts with a little contact cleaner and a Q-tip can help battery life.
But I'll second that JD Ultimate is a great investment.
:-D :-D
Posted 06 January 2012 - 09:46 AM
Everyone's usage varies and there are many factors that play a role with battery life like ppl have mentioned weak signal.
I have exchanged phone once already cause the last one gave me issues. I left it on 3g all the time to save battery and one day I couldn't get 3g at all, I switch to 4g and that worked. After being on the phone with Verizon and going through all the steps I had to factory reset the phone so 3g would work again, this was after the update. That's when I decided to replace the phone with a new one and left 4g on all the time. I had little issues with data with occasional drops here and there and when it does happen I toggle airplane mode on/off.
If all else fails it might be a bad phone.
Posted 06 January 2012 - 09:48 AM
Posted 06 January 2012 - 12:52 PM
Woke up at 11 phone is at 80% at 1. This was all stand by
Whoa! Stock?
Posted 06 January 2012 - 01:49 PM
Currently 50%
Posted 06 January 2012 - 03:45 PM
Posted 06 January 2012 - 05:21 PM
Sent from my Rooted Droid Razr
Posted 08 January 2012 - 05:12 PM
Battery life is worse than before!
Sent from my DROID RAZR using TapatalkI was thinking of giving up on the whole exchange thing and just getting an extended battery, what do yall think?Also, if I did decide to peruse another exchange, would Verizon be easily inclined to exchange?
Posted 09 January 2012 - 12:30 AM
Sent from a device of some sort. Maybe such a new device that I only had to think it..... BAM it is here
Posted 09 January 2012 - 09:47 AM
Best of luck.
Posted 10 January 2012 - 02:40 PM
Screen timeout was 15
Brightness about 25%
Wi-fi off
Bluetooth Off
Pocket Detection off
Screen animations off
CDMA/LTE ON
Is this "reasonable" battery? Doesn't seem like it since my phone was on stand-by. Also, seems odd that the average Joe who doesn't know what cdma even means, would be able to disable their 4g, so I can't imagine the device is supposed to get this kind of battery life.
Posted 10 January 2012 - 03:01 PM
