i would gladly suply anymore information if needed.
Green robot after using house of moto
Posted 01 February 2014 - 09:17 PM
Posted 01 February 2014 - 09:19 PM
well after looking at the fastboot text my battery was apparently low...
Posted 01 February 2014 - 10:01 PM
got this a different go around... what am i doing wrong?
Posted 02 February 2014 - 07:14 AM
I see the problem. You are not the only one to have this issue. I'll post a solution in a minute. I'm going to beotch slap moto.
Posted 02 February 2014 - 07:22 AM
Follow these steps EXACTLY please:
o) Download:
o) Copy that to your HouseOfMoto\xt907 directory
o) Run the FXZ-ScriptGenerator.jar (it's an executable jar)
o) Press the ... button and select the VRZ_XT907_9.8.1Q-94-1_CFC.xml file
o) Enter xt907 for the model
o) Press the generate button
Then try running the House of Moto again with the KEEP DATA script.
Posted 02 February 2014 - 05:24 PM
after doing that i got this...
Im not understanding what i did wrong.
Posted 02 February 2014 - 05:26 PM
It's not finding your phone. It has to be in AP Fastboot mode and plugged in.
Posted 02 February 2014 - 05:31 PM
it is plugged in and also in ap recovery... i am also even using my OEM usb cord
Well, fastboot doesn't see it. Don't know what to tell you.
Posted 02 February 2014 - 06:22 PM
thats fine i figured it out
Posted 03 February 2014 - 10:39 AM
What did you do to fix it?
- livinginkaos likes this
