I have a Mac. All drivers are there and both Motorola apps are on my computer and installed.
I've tried at least 3 utilities to try to root my Razr and I have gotten no luck (That includes cydia impactor(which told me that rooting was not possible), droid razr root utility, and another few I can't remember at the moment, regardless they all failed). Connected as media device, check, SmartActions data cleared, check, debugging on, check. With droidrazrroot, and razrblade I believe, the Terminal always hits phase 3, I get a line that says something like this
"failed on '/data/logger' - Permission denied
failed for /data/logger, File exists"
Or
"Mount failed" "remount failed"
Everything else seems to do fine on Terminal, my phone reboots every time as Terminal says it will, I copied and pasted what the OP of the Jellybean Root for Mac said to put into the Terminal... Does mine have some sort of patch making it impossible? The fact that I have a Mac doesn't make anything easier either.
And I've been at this for at least 20-30 minutes now and have gotten no luck whatsoever.
You can send this thread to the right place if needed, I'm 100% new and just wanted to try to root my Razr, considering I want to try it out, get used to it, and whatnot since I plan to get a new phone in the near future which I would also like to root.
