Big Brother Is Watching! Bionic And Razr Users On Ics Read! [Updated]
90 replies to this topic
#1 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 24 August 2012 - 01:19 PM
There is a script located in ~/system/bin/ entitled 'bugtogo.sh' that does a long of things to our device we do NOT want them doing. I higher suggest anyone running 215 or a ROM based off of 215 such as Arctic, Simplex (not sure if its stuck in there), use a Root file manager like Root Explorer to delete this script.
UPDATE: If you are a Bionic user check for this as well! Users report seeing it on 232 at the least. Also ANYONE on an ICS stock rom or 214 or even should check too.
The contents of the file can be found here:
Here are some tidbits...
If you do not want to be an unwilling bug tester for Motorola then remove this from your device. I am making sure any future releases of ROMs I am involved with will now not ship with this script. Please take care of yourselves!
  • mugsy77, disturbed58, HouseMD and 3 others like this
#2 PillClinton
PillClinton
    #FireGaryBettman
  • 441 posts
  • Twitter:530SharksFan
  • LocationNorCal
Posted 24 August 2012 - 01:23 PM
Done! Thanks for the heads up Matt, much appreciated!!
  • wabmorgan likes this
#3 roBrey85
roBrey85
    Brey
  • 29 posts
  • LocationVegas
thank you sir!
#4 Shinare
Shinare
  • 235 posts
Posted 24 August 2012 - 01:35 PM
Thank you!
#5 Aliceics
Aliceics
    Graphic Designer | Themer
  • 550 posts
  • Twitter:alicerzr
  • Google+:littlemissalice1@gmail.com
Posted 24 August 2012 - 01:36 PM
Confirmed on SimplexROM. Thanks for the heads up!
EDIT: After deleting none of my texts are going through, rebooting and trying again.
EDIT 2: SMS works after a reboot, weird. Anyone else have this problem?
#6 nin
nin
  • 144 posts
  • LocationPA
  • Current Device(s):Galaxy S3
Posted 24 August 2012 - 01:42 PM
Eclipse gone now
#7 twinkyz1979
twinkyz1979
    Veteran Flasher
  • 188 posts
  • LocationOhio
  • Current Device(s):Motorola Droid Ultra XT1080
Posted 24 August 2012 - 01:54 PM
Found it on my Bionic running 6.7.238 as well and removed it.
#8 mugsy77
mugsy77
  • 235 posts
  • Current Device(s):RAZR MAXX
Posted 24 August 2012 - 02:14 PM
Done. You'd think it would be an option under Settings that would say, Yes, I would like to send in info yada yada.. Good find
#9 Thepatriotvirus
Thepatriotvirus
  • 68 posts
  • LocationCalifornia
Posted 24 August 2012 - 02:23 PM
Found in SpeedLite 1.1
#10 JustWantsToSeeLinks
JustWantsToSeeLinks
  • 5 posts
Posted 24 August 2012 - 02:49 PM
Found it on the 211 OTA as well
#11 SnoDrtRider
SnoDrtRider
  • 95 posts
  • Twitter:SnoDrtRider
  • Google+:SnoDrtRider
  • LocationSouth Jersey or Tug Hill, NY
  • Current Device(s):Droid Maxx, Motorola Xoom Wi Fi
Posted 24 August 2012 - 03:00 PM
Confirmed and on the 211 leak from Matts utility as well... possibly been there all along and no one noticed.
  • mattlgroff likes this
#12 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 24 August 2012 - 03:12 PM
Yeah it's been around since Feb. maybe?
#13 thrasher194
thrasher194
    http://androidn00b.com/
  • 226 posts
  • Google+:Thrasher194@gmail.com
  • LocationNorthCarolina, USA
  • Current Device(s):Motorola G4 Play (xt1609)
Posted 24 August 2012 - 03:36 PM
Delete Delete Delete... Done!
#14 mrredpants
mrredpants
  • 90 posts
  • Twitter:@misterredpants
Posted 24 August 2012 - 03:40 PM
I just renamed extension to. Bak
DROID BIONIC ice'd with some variant of 232 leak
#15 k.c.cole
k.c.cole
    Droid Ninja
  • 140 posts
  • Twitter:kcalebcole
  • LocationColorado
  • Current Device(s):Motorola Droid RAZR M
Posted 24 August 2012 - 03:41 PM
Confirmed in SPJester's Liquid Blur 1.1
From my BAMF N7 W/ Motley kernel @1.6Ghz
#16 dautley
dautley
  • 66 posts
  • LocationTN.
  • Current Device(s):HTC One (M8) , Nexus 7 (2012), Nexus 10
Posted 24 August 2012 - 03:48 PM
removed from .232, I always figured these "leaks" could phone home somehow. :)
#17 mugsy77
mugsy77
  • 235 posts
Posted 24 August 2012 - 03:52 PM
Sheet...
I've been on Simplex 1.2 for weeks and after removing this file, I lost data... Completely...
Tried phone info app as well as Mobile Networks/Network Mode.
Anybody else have this issue? I promise I have done nothing to my phone other than delete that file.
Tried deleting cache/dalv, nada... Had to reload the phone
#18 Maxxaholic
Maxxaholic
  • 628 posts
  • LocationWashington, USA
Posted 24 August 2012 - 04:02 PM
Anyone have any issues removing from the .215 leak? Im runnin .215 with arctic on my maxx.
sent from my Arctic RAZR using xparent sky blue tapatalk2
#19 Aliceics
Aliceics
  • 550 posts
  • Twitter:alicerzr
Posted 24 August 2012 - 04:06 PM
Sheet...
Yes and I second what he said. Do NOT remove this file on SimplexROM! Data gets buggy and SMS stops working!
As for you mugsy a simple reflash of the ROM should fix you up, no need to wipe data. ROM script will wipe cache for you.
  • mugsy77 likes this
#20 zero
zero
  • 86 posts
Posted 24 August 2012 - 04:11 PM
Deleted then rebooted and don't seem to have any problems with data or SMS. Also deleted the bug2go folder on SD card. Running Simplex 1.2, 211 build w/ 214 kernel.
