my 926 was bricked after a failed attempt to push framework-res.apk its stuck on the boot screen. i did successfully root the phone. now i am having a very difficult time locating the update.zip for 9.18.94 could some one help me get a link please. greatly appreciated. thanks.
bricked xt926 on 9.18.94.
Posted 14 March 2014 - 08:41 PM
Posted 14 March 2014 - 09:13 PM
First this (use the last one, 9.30.1, it's the same as .94):
or
Then use the FXZ with House of Moto or RSD:
Posted 15 March 2014 - 05:58 AM
outstanding, thanks for the help. i have very little experience with Rooting. i used to be heavily into jailbreaking iOS, but that way a while ago. thanks again for the help.
Posted 15 March 2014 - 06:36 AM
we'll I've followed the correct steps for house of moto, and I'm getting "The system cannot find the path specified".
Posted 15 March 2014 - 06:41 AM
then you did not follow the directions, otherwise it wouldve found the correct files
Posted 15 March 2014 - 06:51 AM
FXZ(9.30.1.XT926) is completely extracted to the root of fxz_xt926, snapdragon support and scrips are also within that folder. i have the motorola device drivers installed(works, since i was able to push my framework-res.apk to the phone). The phone is in AP Fastboot. I've also tried the RSD lite method, same outcome. what am i overlooking?
Posted 15 March 2014 - 07:02 AM
the error you got tells me you arent in the correct folder when you run the script. Other than that, since youre not posting anything that we can work with, we cant be sure. Read the HoM thread again, and post the files that Sam requires for troubleshooting and maybe we can figure it out.
Posted 15 March 2014 - 07:05 AM
Here are the Log files from HoM
Posted 15 March 2014 - 07:06 AM
SWDL log
Posted 15 March 2014 - 07:14 AM
you dont have all the folders so something happened when you extracted or something....you should have a Windows subdirectory and a Darwin and Linux one as well.
Posted 15 March 2014 - 07:19 AM
ok so i should just extract the Snapdragon FXZ support as is to the FXZ_xt926 folder. and not just the .exe and the .dll
Posted 15 March 2014 - 07:20 AM
Follow Sams directions
Posted 15 March 2014 - 07:24 AM
ok, thanks for that. now i have a fail for my negligence. my batter isn't at a optimal level.
- cmh714 likes this
Posted 15 March 2014 - 07:28 AM
although the bottom has me wondering if maybe something else could go wrong once i have charged enough. (the invalid argument lines to the bottom)
Posted 15 March 2014 - 07:33 AM
we can figure that out but you do need to get a better charge.....let me look at the script.
Posted 15 March 2014 - 07:36 AM
do u need to see another so i can post it.?
Posted 15 March 2014 - 07:53 AM
It's failing due to the battery charge. Fix that and it'll work.
- RikRong likes this
Posted 15 March 2014 - 08:02 AM
I responded. If it's an issue, well...
- cmh714 likes this
Posted 15 March 2014 - 07:31 PM
ok gentlemen, phone is fully charged, and still same failure. i rooted this using motochopper.
Posted 15 March 2014 - 07:36 PM
also, forgot to mention. last night after the boot screen loop, i tried to do a factory recovery from the boot loader. that failed also. then it continues on the boot loop. it did manage to format the phones internal flash memory. i wonder if that has something to do with why i can't use HoM.
