Soak for Razr HD incoming?
48 replies to this topic
#41 livinginkaos
  • 15,038 posts
Posted 09 May 2014 - 05:50 PM
I will upload mine to Drdevs if I ever get home.
Sent from my S-Offed One M8
  • johnthehillbilly and cmh714 like this
#42 livinginkaos
  • 15,038 posts
Posted 09 May 2014 - 05:51 PM
And I will test for root stuff.
  • SamuriHL, johnthehillbilly and jtommyj like this
#43 XE_Nerd
XE_Nerd
  • 193 posts
  • Current Device(s):DROID RAZR HD, HTC Rezound
Posted 09 May 2014 - 06:31 PM
Is this something that can only be installed if invited to the soak?
#44 johnthehillbilly
Posted 09 May 2014 - 06:40 PM
Once its uploaded and available..... You should be able to flash in STOCK recovery..... However......you will need to be 100% stock AND I would hold off until it is "tested" ......
#45 XE_Nerd
XE_Nerd
  • 193 posts
Posted 09 May 2014 - 06:41 PM
Ok, thanks, will be waiting for the word ;)
  • johnthehillbilly likes this
#46 johnthehillbilly
Posted 09 May 2014 - 06:46 PM
yeah.... You never want to "blindly" take or flash an OTA. ... Especially if you value root and ROMs .... LOL :)
  • RikRong likes this
#47 XE_Nerd
XE_Nerd
  • 193 posts
Posted 09 May 2014 - 10:09 PM
yeah, I don't have root, running the last update stock
#48 jewbydoo
jewbydoo
  • 26 posts
Posted 10 May 2014 - 08:47 AM
HI all, lurker here.
So I used to have an unlocked bootloader, but there was a mechanical failure and I turned it into Verizon (surprisingly without repercussion; I was able to warranty in my phone a time after that), this caused my to get a Razr HD with version 9.20. No unlocking for me.
What I'd like to know is (when it's safe and "tested"), how might I flash this onto my phone. It was stated earlier that the phone must be three billion% stock in order to take in the soak update (which I downloaded). Would this be doable through RSD Lite or am I out of the loop on something?
#49 speedcan
speedcan
  • Current Device(s):Droid Razr HD Maxx
Posted 10 May 2014 - 08:52 AM
At the end of the soak test. If there are no major issues. It should be sent as an over the air update "ota" by Verizon.
