Posted 25 August 2012 - 06:20 PM
Posted 25 August 2012 - 06:49 PM
I'm trying to disable the background behind the notification bar from dimming when you pull it down in JellyBean/CM10 does anyone have any idea where I should be looking and what to edit. I have dug through Framework-res & SystemUI and have yet to find anything related to it.
Have you tried looking through the XML's? Sounds like something that an xml would be in charge of.
Posted 25 August 2012 - 06:54 PM
I have but didnt see anything related to it. I found a few that I thought was it but had no luck.
Posted 25 August 2012 - 06:57 PM
Just out of curiosity, why do you want to stop it from dimming? With the status bar down you're not really looking at what's behind it anyway
Posted 25 August 2012 - 07:00 PM
In my rom I have a transperent black notification background and it looks like crap with the background dim.
Posted 25 August 2012 - 07:02 PM
Oh that would explain it haha. If you want to send me the systemui and framework ill take a look i may have an idea or two you may not have thought of.
Posted 25 August 2012 - 07:19 PM
Thanks man I appreciate it.
Posted 25 August 2012 - 07:27 PM
I'll take a look at it in the morning, i need some sleep
Posted 25 August 2012 - 07:38 PM
Hell yeah I know what you mean. take your time theres no rush.
#10 Guest_24v_*
Posted 26 August 2012 - 05:12 AM
- lownslow200sx likes this
#11 Guest_24v_*
Posted 26 August 2012 - 05:24 AM
Posted 26 August 2012 - 09:19 AM
Posted 27 August 2012 - 07:05 PM
Also tagged with one or more of these keywords: Theme, CM10, Rom, JellyBean
