Help Droid Razr HD Stuck on Encryption Unsuccsesful Screen
37 replies to this topic
#1 tom398
tom398
  • 8 posts
  • LocationIndonesia
  • Current Device(s):Motorola Droid 3
Posted 24 March 2014 - 07:01 PM
Help anyone can help me.
my phone is droid razr hd on 9.18.94, and i ve already root, but with lock boot loader
last week while i browse using chrome, i got virus warning and asking me to install baidu faster fix.
and i ignore it. but my phone start to over heat maybe, on iddle screen it temp gan rise to 40celcius. but i didnt get the warning again. untill the next day at night i got this virus warning again. then i shut off the phone, on next morning i got this Encryption Unsuccsesful screen with reset button and back button. i try the reset button, and nothing happen. i try back button, it loop at Encryption Unsucseccful screen.
so i try to reset from recovery. wipe data/cache. but it dont work
i try rsdlite 6.15 and 6.14 with xml from sbf.org(lastest firmware same as mine 9.18.94) but its not working, and i tried to delete getvar, its still not working.
i try droid razr hd utility 1.34, 1.33, 1.21 its still not working.
on xda i gt information said its internal memory problem. and on this forum i got DROID_RAZR_HD_Utility_1.3.gpt fix ( to fixing partition memory) n its still not working. the result from DROID_RAZR_HD_Utility_1.3.gpt fix is
post-69493-0-87241200-1395716385_thumb.j
i try on command promt with adb, the device list is empty, but on fastboot or mfastboot. it found my device.
please can anyone help me....
my phone can still charging....
#2 johnthehillbilly
Posted 25 March 2014 - 05:55 AM
Try using the house of moto......
with the FXZ file from here
#3 tom398
tom398
  • 8 posts
  • LocationIndonesia
Posted 25 March 2014 - 04:01 PM
it cant too.... i try house of moto, and try with rsd, it have same result as rsd lite 6.15 or 6.14 and fastboot from house of moto result failed too.... i already have this sbf file, and i try to chek the md5 its same as sbf droid org
#4 cmh714
Posted 25 March 2014 - 04:17 PM
Since your in Indonesia is that a 925 or a 926?
  • johnthehillbilly likes this
#5 johnthehillbilly
Posted 25 March 2014 - 04:24 PM
Good catch cmh :)
#6 cmh714
Posted 25 March 2014 - 04:25 PM
not sure when we get these from across the world....just want to double check ;)
#7 tom398
tom398
  • 8 posts
  • LocationIndonesia
Posted 25 March 2014 - 10:56 PM
droid razr hd dont come to indonesia. its droid razr hd xt926. in indonesia motorola not good, only put some lower device, and they lose to korea and china brand. i bought it from seller who usualy buy handphone from foreign country which havent come in indonesia. rumor said moto g will came here, but its just rumor. and indonesia motorola cant fix handphone they dont sell it here.
#8 cmh714
Posted 26 March 2014 - 05:42 AM
ok, then start giving us much more details on where you fail in the process. You MUST be using USB 2.0 ports and the original Moto cable the phone came with.
#9 SamuriHL
  • 43,368 posts
Posted 26 March 2014 - 07:00 AM
Assuming it's the correct FXZ, it's failing to send the files properly to the phone.  USB cable, driver, or USB port problem.  As was said, you absolutely can NOT be using a USB 3 port for this.  You should be using the USB cable that came with the phone (yes, it matters), and the moto driver should be up to date.
  • johnthehillbilly and cmh714 like this
#10 tom398
tom398
  • 8 posts
  • LocationIndonesia
Posted 26 March 2014 - 06:35 PM
yup, i m using usb 2.0, i ve experienced using usb 3.0 to flash droid 3, resulting my comp hang. then i only using usb 2.0 for flashing. and i m using the lastest driver from motorola. MotorolaDeviceManager_2.4.5, and i m using win 7 64 bit, try to formating, but still have the same result.
this is the result from house of moto with full wipe (fastboot)
post-69493-0-79486200-1395887300_thumb.j
when i try rsd method its start then back to finish with no result
and this is the result using rsd 6.15 with original xml(with getvar)
post-69493-0-40728800-1395887430_thumb.j
and this is the result when i remove getvar
post-69493-0-16005400-1395887466_thumb.j
this is the result by droid razr utility 1.34
post-69493-0-23970800-1395887512_thumb.j
all back to encryption unsuccsesful
my phone can still be charge. i try with full charged
its the fast boot mode
AP Fastboot Flash Mode (S)
10.9B(*) (sha-1e9f557, 2013-09-25 16:26:59)
eMMC Info : Size 16GB
Device is LOCKED, Status Code: 0
Battery OK
Connect USB
Data Cable
Fastboot Reason : Boot menu selected
#11 SamuriHL
  • 43,368 posts
Posted 26 March 2014 - 06:39 PM
Something screwed up is going on.  You're having a similar issue to what someone in my HoM thread is having.  Identical in fact.  WTF are you guys doing?!  :p  What's the FXZ filename you're flashing?
#12 transmissiontech
transmissiontech
    Your Tranny Specialist
  • 7,484 posts
Posted 26 March 2014 - 06:52 PM
Long shot here, but was wondering..what if they had something on there sd card that was blocking the phone memory some how.... i wonder if he pulls his ext sd card and try flashing what would happen...like i said its a wild guess.
Google pixel 32 gig....
#13 johnthehillbilly
Posted 26 March 2014 - 06:53 PM
Judging by this..... He/she is flashing the proper FXZ ....
  54.77KB   7 downloads
Maybe a different (older) version of RSDLite would work......?
#14 johnthehillbilly
Posted 26 March 2014 - 06:56 PM
That's not entirely impossible or unheard of..... ... I've seen "leftovers" on internal or external storage drastically impach a flashing process...... Good suggestion
I've also seen antivirus / firewall block a flash...... (But that produces a different error typically)
#15 SamuriHL
  • 43,368 posts
Posted 26 March 2014 - 06:57 PM
Could try 6.1.4 and see if that helps. I don't think the ext card would matter one way or the other as it's never accessed during fastboot mode. Something is definitely screwy here.
#16 johnthehillbilly
Posted 26 March 2014 - 07:05 PM
Both are starting to appear like hardware failure(s)........ But two identical failures in the same day?
#17 SamuriHL
  • 43,368 posts
Posted 26 March 2014 - 07:11 PM
Possible but I'd like to explore some other possibilities first.
#18 tom398
tom398
  • 8 posts
  • LocationIndonesia
Posted 26 March 2014 - 07:34 PM
i dont do anything to my phone, i just root it, using titanium back up, etc... its working fine for maybe a month, and when i browsing using chrome it suddenly pop up warning that my phone is infected with virus( trojan is i m not mistake) then asking me to install baidu faster fix, of course i ignore this baidu thing. n my phone start to heat up in my pocket(usually heat only happen when i using to call or using aplication). then it went normal until next day i got virus massage again with baidu. then i just shut off my phone. i just preparing to sbf it on next day but its showing that Encryption Unsuccsesful, n cant do anything untill now.
n i ve tried rsd 6.14 before. same result.
n i also try your samurai xml script with same result.
yesterday wanna try with ubuntu. but dont have moto driver for ubuntu, n it said that motorola dont make / support driver for droid razr hd on linux
#19 SamuriHL
  • 43,368 posts
Posted 27 March 2014 - 02:49 AM
Linux doesn't require any driver. I really don't have any ideas left for this issue.
#20 cmh714
Posted 27 March 2014 - 05:46 AM
For starters, RSD doesnt recognize the device since the left hand window is empty of information........
