Computer not recognizing phone
33 replies to this topic
#1 Papa T
Papa T
    ROM Flashaholic
  • 188 posts
  • Twitter:@JTHardee
  • LocationDouglas (South Georgia)
Posted 25 March 2014 - 06:18 AM
Hello again to all.  Been a while since I've written anything because I thought I was getting rid of my RAZR.  Decided to undo all my rooting and go back to stock.  Now I want to flash another rom, but when i plug my phone into the computer, it doesn't recognize the phone.
I remember there was a place to change how it would read the phone, mass storage device, etc.  But now I can't find that option anywhere.  Can someone point me to where that is?
Thanks!
#2 johnthehillbilly
Posted 25 March 2014 - 06:22 AM
The USB modes are in the pull down menu on the phone......... However , you should update the Motorola drivers on your computer (get them here if you need
#3 Papa T
Papa T
    ROM Flashaholic
  • 188 posts
  • Twitter:@JTHardee
Posted 25 March 2014 - 06:25 AM
There in lies the problem.  The pull down menu is no longer on the phone.  How do I get it back?
#4 johnthehillbilly
Posted 25 March 2014 - 06:29 AM
Then what you need is here....
)#entry227369 ....... Update drivers then run this utility..... You should be good to go :)
#5 Papa T
Papa T
    ROM Flashaholic
  • 188 posts
  • Twitter:@JTHardee
Posted 25 March 2014 - 06:33 AM
Yep, did that first and still no luck.  However, does it matter that I'm running Windows 8.1?  I've not tried it on an earlier version of windows.
#6 johnthehillbilly
Posted 25 March 2014 - 06:38 AM
Yes windows 8 may make a difference....... Try again but run the .bat file as administrator........ If that don't work, try an earlier windoze version.....OR..... Grab a "live CD " of a Linux distro and run it on it :)
If that fails, you can run it thru the House of Moto......
  • Brutus06 likes this
#7 livinginkaos
Posted 25 March 2014 - 06:53 AM
HoM on Linux Live CD really is the way to go the more I think about it.  Makes the driver issue go away completely.
  • johnthehillbilly and Brutus06 like this
#8 johnthehillbilly
Posted 25 March 2014 - 06:59 AM
Absolutely !!!!!
#9 Papa T
Papa T
    ROM Flashaholic
  • 188 posts
  • Twitter:@JTHardee
Posted 25 March 2014 - 10:16 AM
I'm still not getting the computer to recognize the phone.  And there is no drop down menu to select how the phone should be connecting to the computer.  Frustrated but not out.
#10 livinginkaos
Posted 25 March 2014 - 10:18 AM
If you go into setting, Storage, then menu, you don't get the USB connection method choice?
#11 johnthehillbilly
Posted 25 March 2014 - 10:21 AM
Was the utility or House of Moto successful?
If so, it should have "reset" everything back to stock......
Then with updated USB drivers it should be fixed.........
#12 Papa T
Papa T
    ROM Flashaholic
  • 188 posts
  • Twitter:@JTHardee
Posted 25 March 2014 - 10:22 AM
That's where it is located.  I just didn't hit the menu button to get the options.  THANKS!!!!
#13 johnthehillbilly
Posted 25 March 2014 - 10:23 AM
Also........ Have you enabled USB debugging ?
#14 Papa T
Papa T
    ROM Flashaholic
  • 188 posts
  • Twitter:@JTHardee
Posted 25 March 2014 - 10:25 AM
Yes.  Had that set the whole time.
#15 johnthehillbilly
If you have no pull down menu at all ..... That still is something wrong within the phone :(
#16 Papa T
Papa T
    ROM Flashaholic
  • 188 posts
  • Twitter:@JTHardee
Posted 25 March 2014 - 10:28 AM
Which mode should I have the usb set too?  I forget.
#17 johnthehillbilly
Posted 25 March 2014 - 10:33 AM
Depends on what you are doing....... If you are trying to root....... MTP mode Trying to run the utility or HoM.... Boot into fastboot...... File transfer....... Mass storage modr
#18 livinginkaos
Posted 25 March 2014 - 10:34 AM
If you are trying to root, use the moto safe root, don't mess with RazrBlade.
  • johnthehillbilly likes this
#19 Papa T
Papa T
    ROM Flashaholic
  • 188 posts
  • Twitter:@JTHardee
Posted 25 March 2014 - 10:37 AM
Yes, I am trying to root and then flash a rom.
#20 johnthehillbilly
Posted 25 March 2014 - 10:38 AM
Follow the link kaos posted.....:)
  • livinginkaos likes this
