[Bionic][Mod] 1% Battery For Stock .232 .235 .238 .242 .244 .246 .247 **now Includes Webtop
bionic 1% accurate battery mod
49 replies to this topic
#1 DLuke
DLuke
    Bionic Modder
  • 69 posts
  • LocationNor*Cal
Posted 03 September 2012 - 05:25 PM
---This is a 1% Battery Mod for Stock ICS leaks 6.7.232, .235, .238, .242, .244, .246, & .247---
***For those of you wondering... the OTA .246 Update is IDENTICAL to the previously leaked .246.. so YES all .246 files you see here will work with the OTA.. Enjoy!
***Now Includes Webtop as well! See instructions below for adding 1% increments and icons for webtop.
First off, like most any "theme-ing" type mods, your system needs to be deodexed
-If you need to deodex first, the Zips for your build are below.. otherwise if you are already deodexed, just pick your battery icons, flash, and enjoy!
***Before you start.. you may want to make a nandroid backup just in case
***All Zips are meant for installing through CWM Recovery via Bionic Bootstrap
*created by mhous33
*created by T3T3Droid
*created by Twinkyz1979
-To deodex, download the deodex zip for you build from above and...
  • Put the deodex .zip on the root of your sd card (external sd card)
  • Reboot into CWM Recovery via Bionic Boostrapper
  • Go to 'install zip from sd card' (not 'apply update')
  • Then select the deodex .zip file
  • Once the install is complete, Wipe Cache and Dalvik (dalvik wipe located in "Advanced")
  • After the wipes, Reboot, and your device will automatically optimize your newly deodexed system files
-Now to install the 1% Battery Mod (the links to the .zips will be below as there are many options for your battery icon)
  • The process is basically the same as installing the deodex .zip
  • So, Download the file from below with your choice of battery icons
  • Put the battery mod .zip on the root of your sd card (external again)
  • Reboot into CWM Recovery via Bionic Bootstrapper
  • Then select the DLuke Battery Mod file you downloaded
  • Once the install is complete reboot and Enjoy your 1% Accurate Battery
--== Here are the options for your battery icons and their corresponding .zip files ==--
***(All icons were found over at XDA.. thank you to the designers!)
  42.18KB   79 downloads
  42.71KB   121 downloads
^^This one is a 'Hybrid' that i made for myself. It has the top set for when the phone is in a regular state, and the bottom set for when it is charging ( the circle like pulsates when charging). ***top icons created by mrvirgina, bottom iocns by Vertumus
- for 232 & 235
- for 238
- for 242
- for 244
- for 246
- for 247
^^This is just the full set of these icons. ***icons created by mrvirgina
- for 232 & 235
- for 238
- for 242
- for 244
- for 246
- for 247
^^This is the full set of these icons. ***icons created by Vertumus.
- for 232 & 235
- for 238
- for 242
- for 244
- for 246
- for 247
  40.43KB   60 downloads
^^ Pretty much stock battery with white numbers. ***icon creator unknown at this time.
- for 232 & 235
- for 238
- for 242
- for 244
- for 246
- for 247
  47.3KB   60 downloads
^^ Thick bar, nice big numbers. ***icons created by Vertumus.
- for 232 & 235
- for 238
- for 242
- for 244
- for 246
- for 247
  49.32KB   58 downloads
^^ Thin Circles. ***icons created by nbeebe24.
- for 232 & 235
- for 238
- for 242
- for 244
- for 246
- for 247
  39.56KB   55 downloads
^^This one pretty much looks like this but instead the bar is only blue above 70% and then it changes from green to orange to red as the battery dissipates. ***the icons creator is unknown at this time.
- for 232 & 235
- for 238
- for 242
- for 244
- for 246
- for 247
>>These zips are for if you want the system to report the 1% increments but want the stock battery icons to remain unchanged. So like if you just want the 1% increments to show on some other widgets you may have or something. (someone had requested these at one point so i figured id put them back up) .. And also you can you these if you just want to add the 1% battery mod for only webtop.
- for 232 & 235
- for 238
- for 242
- for 244
- for 246
- for 247
***Adding 1% Battery for Webtop***
**If you want one of the webtop addon mods for the newer leaks (.244, .246 or .247) they will be available upon request.. pm me for details
---Ok, now if you are a webtop user like myself and would like to add the 1% Battery increments and icons for webtop:
  • First, in order to add the 1% Battery for webtop, you must first flash one of the above regular 1% Battery Mods. So, if you haven't yet, please do so now. (Note: if you would like to only apply the battery mod for webtop and leave the regular mode battery unchanged, then use the "DLuke 1% Battery Mod Stock Icons Unchanged" zip from above)
  • Now, decide which Battery icons you want for webtop, and download the file that corresponds to the regular battery mod that you did from above. The first part of the file name will be the same as the one you flashed from above, and will be followed by this "- Webtop _____ _____". (For Example: If the regular mod you did from above was the "DLuke 1% Battery Mod Hybrid Icons.zip".. and you want to add the "Slow Blink" webtop mod.. then you will download the "DLuke 1% Battery Mod Hybrid Icons - Webtop Slow Blink.zip")
  • Then, just put the zip on the root of your external sd card and install it via CWM Recovery the exact same way you did the first one from above
*All these icons were created by me (hells ya!! haha) (note: just click on the images to see a larger view)
  13.8KB   97 downloads
  12.38KB   63 downloads
  11.54KB   72 downloads
^^^ "Webtop Slow Blink" - This is the one i created for myself. Since, when using webtop in the lapdock, its basically always charging, so instead of just doing the normal battery "filling up", i made it so it tells you what percentage your at and the little screen part of the little phone at the bottom right of the battery icon "pulsates".
--for 232 & 235--
for battery mod for webtop only -
--for 238--
for battery mod for webtop only:
--for 242--
  13.8KB   97 downloads
^^^ "Webtop Thin Numbers" - These ones have the same icons as above for when not charging, but for this one the charging icon is the stock charging battery but with the "filling up" animation added.
--for 232 & 235--
--for 238--
--for 242--
  132.25KB   69 downloads
^^^ "Webtop Fat Numbers" - These were the first set that i made.. i liked the font for the numbers, atleast until i saw them next to the clock font in webtop. but i figured as long as i had em i might as well put em up.. maybe someone else will still like them. and they use the same charging icon as the one directly above (stock charging icon but with "filling" animation)
--for 232 & 235--
--for 238--
--for 242--
**These zips are to return back to the stock 10% increments and stock icons.. Whether you flashed just the regular mod or both it and the webtop addon, just use these, should you ever need/want to do so...
!!Generic Disclaimer: As always I, nor anyone else, is responsible for the s**t you do to your phone!!
Alright people.. If you have any questions or whatever else, just post in this thread or shoot me a pm.. Enjoy!
DLuke
  • mhous33, BytecodeMe, twinkyz1979 and 6 others like this
Posted Image Posted Image
**So ive always held out on adding a donate link because this is just something i do for enjoyment.. but i have received a few requests recently to add one.. so if you enjoy my work and would like to buy me a beer or put some gas in my car, that would be very much appreciated.. but please continue to freely enjoy my mods without any feeling of obligation what-so-ever.. the last thing i want by adding this is for people to stop using my mods because they fell obligated.. Thanks
#2 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
  • Twitter:@BytecodeMe
Posted 03 September 2012 - 06:44 PM
OMG That's a lot of mods, looks like tou worked really hard on this. Nice job. :D
#3 twinkyz1979
twinkyz1979
    Veteran Flasher
  • 188 posts
  • LocationOhio
  • Current Device(s):Motorola Droid Ultra XT1080
Posted 03 September 2012 - 08:20 PM
Thanks for the 242 battery mods :)
#4 DLuke
DLuke
    Bionic Modder
  • 69 posts
  • LocationNor*Cal
Posted 03 September 2012 - 10:00 PM
haha.. thanks dude.. and ya, they've been accumulating since the .232 leak though. so its not like they were all at once or anything
for sure man.. thanks for the deodexed 242
#5 razz1
razz1
  • 17 posts
  • Current Device(s):GS3
Posted 04 September 2012 - 02:32 PM
Thanks for re-posting this. It was getting hard to find and needed it the other day. Thanks for your time and expertise!
#6 acordill
acordill
  • 97 posts
  • Twitter:https://twitter.com/@acordill
  • Google+:http://goo.gl/J90Lv
  • LocationCentral Florida
Posted 04 September 2012 - 03:02 PM
+1
HoB 246 (Thanks to SamuriHL) running Icarus Hd 1.0 (Thanks to Jp1044 and T3T3Droid)
#7 DLuke
DLuke
    Bionic Modder
  • 69 posts
  • LocationNor*Cal
Posted 04 September 2012 - 04:25 PM
ya it was a little shakey there for a min. with the hive and then rombot going down.. i dont foresee anything happening to this one (knock on wood) but there should also always be a perm. thread over at df also.. and ur welcome.. im just glad others can get some use out of them!
#8 acordill
acordill
  • 97 posts
Posted 11 September 2012 - 09:09 AM
Anyone tried using 242 mod on 244 yet?
I noticed the apk's and jar file have been updated in .244 from .242. Don't know if that would make too big a difference.
#9 DLuke
DLuke
    Bionic Modder
  • 69 posts
  • LocationNor*Cal
Posted 11 September 2012 - 11:06 AM
.244?? damn ive been outta the loop the last few days.. my fault.. im downloading now.. my guess is .242 would probably work.. but ill take a look at it.. and ill most likely up date them for the .244 system files anyways, like ive done with the rest.. just gimme a couple days
  • acordill likes this
#10 acordill
acordill
  • 97 posts
Posted 11 September 2012 - 03:08 PM
Awesome I appreciate it!
#11 DLuke
DLuke
    Bionic Modder
  • 69 posts
  • LocationNor*Cal
Posted 11 September 2012 - 05:43 PM
hey just so you know.. the .242 files are fine to use on .244 for right now.. im using them.. between .242 and .244 the services.jar is identical and the deodexed framework-res.apk and SystemUI.apk files only changed by 4 bytes.. not 4 kilo-bytes.. 4 bytes.. hehe.. so if i have some time in the next few days ill throw up some .244 files but until then, you can just use the .242 mods if you want
  • twinkyz1979 and johnlgalt like this
#12 zeroxia
zeroxia
  • 5 posts
Posted 16 September 2012 - 12:34 AM
I flashed the stock .244 ICS leak, and put the deodexed zip upgrade pack. Then flashed the hybrid flavor mod.
The result is shown, but one issue: in the charging state, the number is always 100, which obviously is wrong because the phone is charging... Is this also found in .242 leak?
The world is beautiful for you.
#13 acordill
acordill
  • 97 posts
Posted 16 September 2012 - 08:02 AM
I had same issue on another Rom don't remember if 242 or another one. Just that it is not new on 244.
#14 DLuke
DLuke
    Bionic Modder
  • 69 posts
  • LocationNor*Cal
Posted 16 September 2012 - 11:29 AM
the only time that your phone would dispay 100 while its plugged in is if your system is reporting that the battery is 100% fully charged. its not an error with the mods, however it is possible that your system is reporting the false battery level. its always a good idea to clear your battery stats after flashing a new rom, and should fix the issue your having now.. downloading the free app "BatteryCalibration" is an easy way to do this.. also you should make sure you are wiping cache and dalvik after flashing the deodex zip.. if you didnt, it probably wouldnt hurt to boot into CWM now and wipe both real quick.. hope this helps..
#15 DLuke
DLuke
    Bionic Modder
  • 69 posts
  • LocationNor*Cal
Posted 16 September 2012 - 01:31 PM
***OP updated with .244 files***
only the regular mods though.. haven't had time for the webtop addons yet.. they take a lot longer
  • johnlgalt likes this
#16 mhous33
mhous33
  • 480 posts
Posted 19 September 2012 - 02:57 PM
thanks for the stock icon versions, exactly what i wanted for use with the circles widget :)
#17 DLuke
DLuke
    Bionic Modder
  • 69 posts
  • LocationNor*Cal
Posted 20 September 2012 - 03:45 PM
for sure.. i aim to please!! hah
#18 acordill
acordill
  • 97 posts
Posted 20 September 2012 - 05:03 PM
Where did you get circles widget?
#19 mhous33
mhous33
  • 480 posts
Posted 20 September 2012 - 06:18 PM
atrix hd system dump; if you google it, should be the first post, on xda.
#20 bdazzg1
bdazzg1
    I Break $hit!
  • 359 posts
  • Twitter:@bdazzg1
  • Google+:https://plus.google.com/u/0/+TonyRossBDAZZG1
  • LocationPrescott Valley, AZ
  • Current Device(s):Nexus 6, Droid Maxx, Droid Ultra, LG G2, LG G3, Samsung Galaxy Tab 2 7.0
Posted 22 September 2012 - 11:13 AM
Hey Luke, are you planning on doing the 1% battery for 246?
Sent from my DROID BIONIC using Xparent Blue Tapatalk 2
Also tagged with one or more of these keywords: bionic, 1%, accurate, battery, mod
