Can I replace the EB40 3200 mah battery in my Motorola Droid Razr Maxx XT912 with a 4000 mah battery? Thanks.
Battery Upgrade
Posted 14 April 2014 - 09:57 AM
Posted 14 April 2014 - 10:04 AM
Please remember, its not a sure thing that it can be done...... And it can be damaging to your phone..... However, if you do attempt it and it is successful please post here so it may help others who might want to upgrade as well.....
- johnlgalt likes this
Posted 16 April 2014 - 06:48 PM
I installed the 4000 mah battery in my Motorola Droid Razr Maxx XT912 this afternoon. So far, everything is OK.
- johnthehillbilly likes this
Posted 19 April 2014 - 05:58 AM
The new 4000mAh battery still seems to be working OK. It's hard to say how long it last because this is now a spare phone that is not active on my Verizon account. I turn it on every day and it connects to my router as a WIFI device. So far, it's been 3 days and it's down to 30 percent. Temperature is 77 degrees F.
Posted 04 May 2014 - 09:49 AM
Well, unfortunately, this 4000mAh Replacement battery does not seem to be holding a charge as long as it should. I'm going to see if I can find a stock battery for my Droid Razr Maxx.
Posted 04 May 2014 - 12:26 PM
Yes
Posted 04 May 2014 - 06:32 PM
I haven't opened it back up, but I'm pretty sure nothing like that has happened. I ordered another battery to replace this one. I ordered an OEM 3200mAh battery that should be exactly like the one that came in the phone when it was new. I guess I'll toss the 4000mAh battery and be out $25.
Posted 04 May 2014 - 07:00 PM
Of course, it's possible the phone was damaged when the original battery over-heated and swelled up. I'll find that out when I receive and install the OEM battery I just ordered.
Posted 08 May 2014 - 08:06 PM
I received the OEM 3200mAh battery this afternoon and installed it tonight. So far, it appears to be working as normal. I am going to return the 4000mAh battery for a refund.
Lesson learned: Don't buy off-brand batteries. Only buy OEM.
Posted 09 May 2014 - 07:31 PM
This new OEM battery is working great. I put the Razr Maxx on my wife's line and got her a data plan and retired her flip phone. She's happy.
