4.4 is rolling out, do i need to factory reset because of it?
114 replies to this topic
#1 nal
nal
  • 164 posts
  • LocationIllinois
  • Current Device(s):Droid Razr HD xt907/26, LG G2, Nexus 7 2012
Posted 14 May 2014 - 04:17 AM
I removed all the bloat from the phone and I want to know, do I need to reinstall? If so, how to. Like I've listed I'm running 98.30.1 and I've tried rsd lite and it's just said it failed, I will list later what it said because I'm away my computer. So, do I?
  • godsartist3 likes this
#2 johnthehillbilly
Posted 14 May 2014 - 04:22 AM
You need to be 100% stock to be able to take the OTA...... (Includes all bloatware, stock recovery, etc).....
And yes, as soon as you get the opportunity, we will need any information you can give as far as RSDlite failing...... So we know what steps to take next....:)
#3 livinginkaos
Posted 14 May 2014 - 04:54 AM
100% stock but you do not need to fdr
Sent from my S-Offed One M8
#4 nal
nal
  • 164 posts
  • LocationIllinois
Posted 14 May 2014 - 06:36 AM
From what I recall, it said flash failure unknown fastboot command getvar, I tried deleting the command because one video said it would fix but i got the same issue but with unknown fastboot command OEM instead. I installed the mobility drivers off Motorolas site and rsd lite. I honestly don't know what to do, I restored a few system applications but the rest won't install. So my best try is to use that
FDR?
#5 livinginkaos
Posted 14 May 2014 - 07:05 AM
You must have done something to one of the other commands or left some errant info in there.  You can either use Sam's new tool, or grab House of Moto and using the fxz flash a save data.
FDR?
FDR = Factory Data Reset - you do not need to erase your data.
#6 nal
nal
  • 164 posts
  • LocationIllinois
Posted 14 May 2014 - 07:26 AM
for clarification, my bootloader is locked. Can I have a link to Sam's tool? I'll try it when I get home. I've seen house of moto and it looks a bit complicated, so I don't know if I should try it or not. I've also found a download for all the applications, but it wouldn't let me install them. I guess this is my only option
#7 livinginkaos
Posted 14 May 2014 - 07:31 AM
Oh yeah, locked, don't touch the tool.
#8 nal
nal
  • 164 posts
  • LocationIllinois
Posted 14 May 2014 - 08:58 AM
What else can I possibly do? Can I flash the stock image with safestrap? Or should I try rsd lite.
Like I listed before, those are the issues. What can I try
#9 livinginkaos
Posted 14 May 2014 - 09:41 AM
RSD with the 9.30.1 FXZ.  You can use the attached XML for save data.  Extract the FXZ zip, then place the attachment into the folder along where the original XML is.  Then use RSD with this XML.
#10 nal
nal
  • 164 posts
  • LocationIllinois
Posted 14 May 2014 - 09:47 AM
will it matter that I'm on that firmware, I'll give it a try when I get home, thanks for the help!
#11 livinginkaos
Posted 14 May 2014 - 10:22 AM
No, you can flash over the same thing no problem.  That is the best way to clean up root.
#12 nal
nal
  • 164 posts
  • LocationIllinois
Posted 14 May 2014 - 01:18 PM
Um, where do I put this?
Do I just put it in the folder or replace the notepad file
#13 livinginkaos
Posted 14 May 2014 - 01:22 PM
You can just put it in the folder.  Just when you choose the file in RSD, pick the save data one.
That way you have a copy of the original xml if you need it later.
#14 nal
nal
  • 164 posts
  • LocationIllinois
Posted 14 May 2014 - 01:32 PM
I uncompressed the folder and about to flash, do I just delete the original xml file?
or do I rename it to that and replace it? Sorry, I'm new to android
#15 livinginkaos
Posted 14 May 2014 - 01:44 PM
Just keep it.  You can have multiples in there.  Just choose that one after you click the "..." button in RSD
  86.82KB   16 downloads
#16 nal
nal
  • 164 posts
  • LocationIllinois
Posted 14 May 2014 - 01:48 PM
#17 livinginkaos
Posted 14 May 2014 - 02:16 PM
Did you place the new xml inside the folder with they image files?
  11.33KB   14 downloads
#18 nal
nal
  • 164 posts
  • LocationIllinois
Posted 14 May 2014 - 02:17 PM
Yes.
#19 livinginkaos
Posted 14 May 2014 - 02:34 PM
I see, I have you the xt926 file. Let me get the 907
#20 livinginkaos
Posted 14 May 2014 - 03:27 PM
Here is for the 907
